Crucial 512MB 240DIMM PC2-5400
Quicklinx: 4L42WS00 Mfr#: CT6464AA667
Help your desktop perform at its best. Designed to help your desktop run faster and smoother, a Crucial memory upgrade is one of fastest, most affordable, and easiest ways to improve your system's performance. Crucial memory empowers your desktop to achieve faster application loading times, faster system responsiveness, and increased ability to multitask and handle data-intensive programs. What does this mean? Spend less time staring at loading screens and more time getting stuff done. Crucial desktop modules are rigorously tested at both the component and module levels to ensure that your memory meets the stringent compatibility and performance standards. Every module manufactured is inspected by the Systems Compatibility Group before it leaves the doors. At a fraction of the price of your desktop, an investment in Crucial memory helps your system get up to speed.
Crucial - DDR2 - module - 512 MB - DIMM 240-pin - 667 MHz / PC2-5300 - unbuffered
Memory module
512 MB
Memory Type
DDR2 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
667 MHz (PC2-5300)
Latency Timings
CL5
Unbuffered
Voltage
1.8 V
Sony VGP-MM512J, DELL A1229410, Dell A1249412, IBM 73P3213, DELL A0375073, HP PR662A, DELL A0375065, DELL A0388044, HP PX975AA, IBM 30R5121, IBM 73P4971, IBM 73P3214, IBM 30R5125, IBM 73P4983, IBM 41X4255, DELL A0740240, DELL A0763379, DELL A0534017, HP P9907AX, HP PU016-69001, HP 396520-001, HP PX975AT, DELL A0498621, HP 382505-001, DELL A0913187, HP EK477-69001, IBM 41A3518, DELL A0740243, DELL A0740246, DELL A0740247, DELL A0740249, DELL A0740251, DELL A0740255, DELL A0740257, DELL A0743628, DELL A0743630, DELL A0743631, DELL A0743632, DELL A0743635, DELL A0743958, DELL A0743963, DELL A0743965, DELL A0743968, DELL A0743969, DELL A0743986, DELL A0743987, DELL A0743988, DELL A0743990, DELL A0743994, DELL A0744000, DELL A0744013, DELL A0744068, DELL A0744073, DELL A0744075, DELL A0744076, DELL A0763378, DELL A0763386, DELL A0763395, DELL A0763396, DELL A0913022, DELL A0913044, DELL A0913200, DELL A1190020, DELL A1213232, DELL A1213233, DELL A1213234, DELL A1213235, DELL A1249408, DELL A1289044, DELL A1292035, DELL A1312864, Kingston D6464E40, Kingston D6464F50, Kingston KFJ2887/512, Kingston KFJ2888/512, Kingston KFJ2889/512, Kingston KTD-DM8400/512, Kingston KTD-DM8400A/512, Kingston KTD-DM8400B/512, Kingston KTH-XW4200/512, Kingston KTH-XW4200AN/512, Kingston KTH-XW4300/512, Kingston KTM3211/512, Kingston KTM4982/512, Kingston KVR400D2N3/512, Kingston KVR533D2N4/512, Kingston KVR667D2N5/512, Crucial MT4HTF6464AY-667E1, Crucial MT4HTF6464AZ-667H1, Crucial MT8HTF6464AY-667F1, Fujitsu S26361-F2887-E112, Fujitsu S26361-F2887-L112, Fujitsu S26361-F2888-E112, HP 382509-001, HP PV560AA, HP 393393-001, HP PV560T, DELL A0740241, DELL A0375067, DELL A0375070, DELL A0498619
ABIT AA8XE
512 MB
Upgrade Type
Generic
DRAM memory module
DDR2 SDRAM
DIMM 240-pin
Speed
667 MHz (PC2-5300)
Latency Timings
CL5
Non-ECC
Unbuffered
Module Configuration
64 x 64
Voltage
1.8 V
Compatible Slots
1 x memory - DIMM 240-pin
ABIT AA8XE
