Crucial 512MB 184Pin DIMM PC3200 DDR RAM Non-Parity CL3
Customer rating: 5.0* (Write a review)
Quicklinx: 2LGMWS00 Mfr#: CT6464Z40B
Help your desktop perform at its best. Designed to help your desktop run faster and smoother, a Crucial memory upgrade is one of fastest, most affordable, and easiest ways to improve your system's performance. Crucial memory empowers your desktop to achieve faster application loading times, faster system responsiveness, and increased ability to multitask and handle data-intensive programs. What does this mean? Spend less time staring at loading screens and more time getting stuff done. Crucial desktop modules are rigorously tested at both the component and module levels to ensure that your memory meets the stringent compatibility and performance standards. Every module manufactured is inspected by the Systems Compatibility Group before it leaves the doors. At a fraction of the price of your desktop, an investment in Crucial memory helps your system get up to speed.
Crucial - DDR - module - 512 MB - DIMM 184-PIN - 400 MHz / PC3200 - unbuffered
Memory module
512 MB
Memory Type
DDR SDRAM - DIMM 184-PIN
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
400 MHz (PC3200)
Latency Timings
CL3
Unbuffered
Voltage
2.6 V
Gateway 5000694, IBM 73P2686, IBM 73P2684, IBM 73P3221, Acer 91.AD346.006, DELL A0388041, Sony PCVA-MM512F, IBM 73P3222, DELL A0547735, Kingston KVR400X64C25/512, DELL 311-2690, DELL A0740402, DELL A0735431, HP 326668-885, IBM 33R4966, HP 445715-885, HP 5187-5691, DELL A0735425, DELL A0735427, DELL A0735436, DELL A0735438, DELL A0735447, DELL A0735476, DELL A0735501, DELL A0735504, DELL A0735506, DELL A0735514, DELL A0735518, DELL A0735519, DELL A0735521, DELL A0740394, DELL A0740406, DELL A0740409, DELL A0740414, DELL A0742801, DELL A0743426, DELL A0743427, DELL A0743736, Kingston D6464D30A, Kingston KFJ2847/512, Kingston KTD8300/512, Kingston KTH-D530/512S, Kingston KTM-M50/512, Kingston KTM3219/512, Kingston KTN-PM400/512, Kingston KVR400X64C3A/512, Acer ME.DT4PD.512, Crucial MT16VDDT6464AY-40BK1, Crucial MT8VDDT6464AY-40BF4, NEC PK-UG-ME010, Fujitsu S26361-F2847-E112, Fujitsu S26361-F2847-E113, Fujitsu S26361-F2847-L112, Fujitsu S26361-F2847-L113, DELL A0546964, DELL A0119249
ABIT SG-80; Gigabyte GA-8IPE1000-G
512 MB
Upgrade Type
Generic
DRAM memory module
DDR SDRAM
DIMM 184-PIN
Speed
400 MHz (PC3200)
Latency Timings
CL3
Access Time
5 ns
Non-ECC
Unbuffered
Module Configuration
64 x 64
Voltage
2.6 V
Compatible Slots
1 x memory - DIMM 184-PIN
ABIT SG-80 , Gigabyte GA-8IPE1000-G
Customer reviews
Write a review for the Crucial 512MB 184Pin DIMM PC3200 DDR RAM Non-Parity CL3 here!
Great!
Reviewed by Anonymous Review Posted 15/05/2005
Incredibly good value for this type and brand, arrived two days after order in perfect condition and have been enjoying it's computer enhancing goodness for several days now. Can't complain about anything, yet another fabulous purchase from Dabs.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Excellent RAM
Reviewed by Matt. Review Posted 30/08/2007
Easy, no hassle install. Went from 2x256 to 2x512 and instantly felt huge increase in speed. Only annoyance was although it was sent out by dabs very quickly I didn't think I'd need to be in for delivery as they are tiny little pieces of hardware, which easily could have been sent in an envelope with some bubble rap inside... instead it came (when i was at work)in a massive box which meant it went back to royal mail sorting office to be picked up a day later!!! Why the silly packaging I don't know, but I'm happy now I've got them lol
  • Overall 5*
  • Ease of use 5*
Recommended
Reviewed by Brian. Review Posted 12/10/2007
Mobo Asus A8N-E using a pair of Reneon? 512s. Asus recommended Kingston chips amongst others but not Crucial. However, reading Kingston reviews in Dabs for like chips persuaded me to Crucial as they use their own chips and had a good press here. Ordered and received a pair of these from Dabs. Different chip layout being populated one side only rather than double sided of the existing chips. Fitted on receipt and immediately fully operational. Next time - Crucial first stop.
  • Overall 5*
  • Ease of use 5*
Read all 14 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
