Crucial 512GB m4 2.5" 9.5mm SATA 6Gbps SSD w/ Bracket
Quicklinx: 7T3WWS00 Mfr#: CT512M4SSD2BAA
The award-winning Crucial m4 SSD delivers powerful performance gains for SATA 6 Gb/s systems. Designed to empower your system, the Crucial m4 SSD offers faster application load times, faster boot times, and increased durability compared to a traditional hard drive. The results speak for themselves: blazing-fast sequential read speeds of up to 500 MB/s - for any file type.
Built with advanced controller technology, Micron proprietary firmware and high-speed synchronous MLC NAND, the Crucial m4 SSD is engineered to deliver consistent, blazing-fast SSD performance. From the extensive research and development that led to its ultimate design, to the hours of testing and validation spent on each NAND component, to rigorous compatibility testing in the Crucial Performance Labs to ensure component functionality, the Crucial m4 SSD is built to last.
There's a reason the Crucial m4 SSD has garnered numerous international awards since its launch - it does what it's supposed to do. No matter what kind of files you're working with on a Crucial SSD, you'll experience high speeds with no drop in performance.
Unlike other SSDs on the market, Crucial SSDs treat all files the same, regardless of whether they're compressed or uncompressed. This is important because the files most people use everyday - videos, mp3s, advanced graphics files and zip files - are compressed files and thus unable to be compressed any further. While many SSDs on the market achieve faster speeds by using file compression, many of the most common file types can't be compressed, resulting in SSDs that often deliver drastically slower speeds than originally advertised. With the advanced technology of a Crucial SSD, however, you'll never have this problem!
  • Enhanced durability
    Built to withstand extreme conditions, this solid state drive operates reliably from 0°C to 70°C and boasts a shock tolerance of 1500 g @ 1 ms, ensuring your data is safe even in the event of sudden impacts.
  • High-speed performance
    With an internal data rate of 500 MBps and a data transfer rate of 600 MBps, coupled with Native Command Queuing (NCQ), this drive delivers swift and efficient performance for demanding applications.
  • Extended reliability
    Featuring a mean time between failures (MTBF) of 1,200,000 hours and compliance with S.M.A.R.T. standards, this solid state drive promises long-term dependability for your crucial data storage needs.
Crucial m4 with Easy Desktop Install Kit - SSD - 512 GB - SATA 6Gb/s
Solid state drive - internal
512 GB
NAND Flash Memory Type
Multi-level cell (MLC)
2.5" x 1/8H (in 3.5" carrier)
SATA 6Gb/s
Data Transfer Rate
600 MBps
Native Command Queuing (NCQ), S.M.A.R.T.
6.985 cm x 10.05 cm x 0.95 cm
75 g
3-year warranty
512 GB
2.5" x 1/8H
SATA 6Gb/s
6.985 cm
10.05 cm
0.95 cm
75 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
500 MBps (read) / 260 MBps (write)
4KB Random Read
40000 IOPS
4KB Random Write
50000 IOPS
Average Latency
1 ms
Reliability
MTBF
1,200,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 22 pin Serial ATA
Compatible Bay
2.5" x 1/8H or 3.5" (with included bay adapter)
3.5-inch bay adapter
UL, FCC, RoHS
Limited warranty - 3 years
70 °C
Shock Tolerance
1500 g @ 1ms
