Your basket is empty
Crucial 4GB (2x2GB KIT) 800MHz DDR2 PC2-6400
Quicklinx: 55XPWS00 Mfr#: CT2KIT25664AA800
Type: DDR2 SDRAM
Capacity: 4GB
Connection: DIMM 240-pin
Speed: 800MHz
Data Integrity: Non-ECC
£39.40 ex VAT
£47.28 inc VAT
Express delivery Order within the next 6 hours for delivery tomorrow
Crucial - DDR2 - 4 GB : 2 x 2 GB - DIMM 240-pin
RAM memory
4 GB : 2 x 2 GB
Memory Type
DDR2 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
800 MHz ( PC2-6400 )
Latency Timings
CL6
Unbuffered
Voltage
1.8 V
IBM 46C7571, HP 501158-001, IBM 40W2991, IBM 46C7568, IBM 46M3065, Kingston KTD-PEM605/4G, Kingston KTH-BL495K2/4G, Kingston KTM5780ALP/4G, Kingston KVR800D2N5K2/4G, Kingston KVR800D2N6K2/4G
4 GB : 2 x 2 GB
Upgrade Type
Generic
DRAM
DDR2 SDRAM
DIMM 240-pin
Module Height (inch)
1.18
Speed
Latency Timings
CL6
Non-ECC
Unbuffered
Module Configuration
256 x 64
Voltage
1.8 V
Compatible Slots
2 x memory - DIMM 240-pin
Crucial 4GB (2x2GB KIT) 800MHz DDR2 PC2-6400 Bundle deal on Crucial 4GB (2x2GB KIT) 800MHz DDR2 PC2-6400
Including:
CoolerMaster High Performance Thermal Paste 2g CoolerMaster High Performance Thermal Paste 2g worth £4.02 | in stock
Akasa Cable Tidy Kit Akasa Cable Tidy Kit worth £3.50 | in stock
StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit worth £10.63 | in stock
Best Value Duratool Antistatic Wrist Band Best Value Duratool Antistatic Wrist Band worth £3.00 | while stocks last
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £2.99 | in stock
£55.71
saving £7.84
Type: DDR2 SDRAM
Capacity: 4GB
Speed: 800MHz
Registered/Buffered: Unbuffered
CAS Latency: CL6
Standard: PC2-6400
Brand: Crucial
Price Range Ex VAT: 0 - 50
