Crucial 2GB kit (1GBx2) DDR2 667MHz (PC2-5300) CL5 240pin
Quicklinx: 7M80WS00 Mfr#: CT2KIT12864AA667
Micron Technology is one of the world's leading providers of advanced semiconductor solutions. Micron's DRAM and Flash components are used in today's most advanced computing, networking, and communications products, including computers, workstations, servers, cell phones, wireless devices, digital cameras, and gaming systems. Micron's mission is to be the most efficient and innovative global provider of semiconductor solutions.
A dual inline memory module (DIMM) consists of a number of memory components (usually black) that are attached to a printed circuit board (usually green). The gold pins on the bottom of the DIMM provide a connection between the module and a socket on a larger printed circuit board. The pins on the front and back of a DIMM are not connected to each other.
240-pin DIMMs are used to provide DDR2 SDRAM memory for desktop computers. DDR2 is a leading-edge generation of memory with an improved architecture that allows it to transmit data very fast.
Crucial - DDR2 - kit - 2 GB: 2 x 1 GB - DIMM 240-pin - 667 MHz / PC2-5300 - unbuffered
Memory kit
2 GB: 2 x 1 GB
Memory Type
DDR2 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
667 MHz (PC2-5300)
Latency Timings
CL5
Unbuffered
Voltage
1.8 V
Kingston KTS-SESK2/2G, Kingston KTS5277K2/2G, Kingston KVR400D2N3K2/2G, Kingston KVR667D2N5K2/2G, Apple MA247G/A, Sun SESX2A2Z, Sun X4200AF, Sun X5278A-Z, Sun SESX2A1Z, Kingston KTA-G5533/2G
ABIT AA8XE
2 GB: 2 x 1 GB
Upgrade Type
Generic
DRAM memory kit
DDR2 SDRAM
DIMM 240-pin
Speed
667 MHz (PC2-5300)
Latency Timings
CL5
Non-ECC
Unbuffered
Module Configuration
128 x 64
Voltage
1.8 V
Compatible Slots
2 x memory - DIMM 240-pin
ABIT AA8XE
