Enterprise-level performance. Tested, qualified, and reliable, Crucial server memory delivers enterprise-level performance. Crucial server memory is available in LRDIMM, FBDIMM, RDIMM, and unbuffered ECC module types. With a wide variety of speeds and densities to choose from, Crucial server memory is designed to meet the needs of server platforms and operating systems, both new and old. Trust Crucial memory for your server and workstation applications, and keep your important data running smoothly.
- Crucial - DDR2 - module - 2 GB - DIMM 240-pin - 800 MHz / PC2-6400 - unbuffered
- Product Type
- Memory module
- Capacity
- 2 GB
- Memory Type
- DDR2 SDRAM - DIMM 240-pin
- Upgrade Type
- Generic
- Data Integrity Check
- ECC
- Speed
- 800 MHz (PC2-6400)
- Latency Timings
- CL5
- Unbuffered
- Voltage
- 1.8 V
- Limited lifetime warranty
- Capacity
- 2 GB
- Upgrade Type
- Generic
- DRAM memory module
- Technology
- DDR2 SDRAM
- Form Factor
- DIMM 240-pin
- Module Height (inch)
- 1.18
- Speed
- Latency Timings
- CL5
- ECC
- Unbuffered
- Module Configuration
- 256 x 72
- Voltage
- 1.8 V
- Compatible Slots
- 1 x memory - DIMM 240-pin
