Crucial 2GB 240PIN DDR3 PC3-8500 NON ECC CL-7
Quicklinx: 4QH0WS00 Mfr#: CT25664BA1067
Crucial 240-pin DIMMs are used in DDR3 memory for desktop computers. DDR3 is the latest generation of memory with an improved architecture that allows it to transmit data more quickly.
A dual inline memory module (DIMM) consists of a number of memory components (usually black) that are attached to a printed circuit board (usually green). The gold pins on the bottom of the DIMM provide a connection between the module and a socket on a larger printed circuit board. The pins on the front and back of a DIMM are not connected to each other.
Each 240-pin DIMM provides a 64-bit data path (72-bit for ECC or registered or Fully Buffered modules). (The Ballistix™ and Ballistix Tracer™ high-performance memory do not come in 72-bit or registered modules.) Standard DDR3 240-pin DIMMs are currently available in DDR3 PC3-8500 SDRAM. Additional speeds will be added as the technology becomes available.
To use DDR3 memory, your system motherboard must have 240-pin DIMM slots and a DDR3-enabled chipset. This is because a DDR3 SDRAM DIMM will not fit into a standard DDR2 DIMM socket or a DDR DIMM socket.
The number of black components on a 240-pin DIMM can vary, but it always has 120 pins on the front and 120 pins on the back, for a total of 240. 240-pin DIMMs are approximately 5.25 inches long and 1.18 inches high, though the heights can vary. While 240-pin DDR3 DIMMS, 240-pin DDR2 DIMMs, 184-pin DDR DIMMs, and 168-pin DIMMs are approximately the same size, 240-pin DIMMs and 184-pin DIMMs have only one notch within the row of pins.
Crucial - DDR3 - module - 2 GB - DIMM 240-pin - 1066 MHz / PC3-8500 - unbuffered
Memory module
2 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1066 MHz (PC3-8500)
Latency Timings
CL7
Unbuffered
Voltage
1.5 V
DELL A1595856, DELL A3132546, DELL A3132548, DELL A2200695, DELL A2290224, DELL A3414609, DELL A3414614, DELL A3414622, DELL A3544256, DELL A3544258, Lenovo 46R3323, DELL A3544260, DELL A3382817, Kingston KTD-XPS730A/2G, IBM 43J5435, DELL A2296386, Kingston KTH9600A/2G, Kingston KTL-TCM58/2G, Kingston KVR1066D3N7/2G, HP KX744-69001, Crucial MT16JTF25664AY-1G1D1, Crucial MT16JTF25664AZ-1G1F1, Crucial MT8JTF25664AZ-1G1D1
Limited lifetime warranty (Germany - 10 years)
ASUS M4A78T-E, M4A79T Deluxe, Z8NA-D6; DFI DK X58-T3eH6, UT X58-T3eH8; Intel Server Board S5500BC, S5500HCV, S5500WB, S5520HC, S5520UR; Workstation Board S5520SC; SUPERMICRO C7X58, X8SAX, X8ST3-F, X8STE, X8STi, X8STi-F, X8STi-LN4; Tyan S7010AGM2NRF, S7012GM4NR, S7016GM3NR
2 GB
Upgrade Type
Generic
DRAM memory module
DDR3 SDRAM
DIMM 240-pin
Module Height (inch)
1.18
Speed
1066 MHz (PC3-8500)
Latency Timings
CL7
Access Time
1.87 ns
Non-ECC
Unbuffered
Module Configuration
256 x 64
Voltage
1.5 V
Compatible Slots
1 x memory - DIMM 240-pin
ASUS M4A78T-E, M4A79T Deluxe, Z8NA-D6 , DFI DK X58-T3eH6, UT X58-T3eH8 , Intel Server Board S5500BC, S5500HCV, S5500WB, S5520HC, S5520UR , Intel Workstation Board S5520SC , SUPERMICRO C7X58, X8SAX, X8ST3-F, X8STE, X8STi, X8STi-F, X8STi-LN4 , Tyan S7010AGM2NRF, S7012GM4NR, S7016GM3NR
