Crucial MX300 Solid State Drive
Instant performance that lasts
Increase the speed, durability, and efficiency of your system for years to come with the Crucial MX300 SSD. Boot up in seconds and fly through the most demanding applications with an SSD that fuses the latest 3D NAND flash technology with the proven success of previous MX-series SSDs. Your storage drive isn’t just a container, it’s the engine that loads and saves everything you do and use. Get more out of your computer by boosting nearly every aspect of performance.
Instantly improve system performance
The Crucial MX300 reaches read speeds up to 530 MB/s and write speeds up to 510 MB/s on all file types so you can boot up almost instantly, reduce load times, and accelerate demanding applications with ease. Plus, our Dynamic Write Acceleration technology uses an adaptable pool of high-speed, single-level cell flash memory to generate blistering speeds throughout the drive’s long life.
Over 90x more energy efficient than a typical hard drive
Extreme Energy Efficiency technology within the Crucial MX300 reduces the amount of active power usage that's consumed by the drive. The Crucial MX300 extends your laptop's battery life by using only 0.075W of power, compared to a typical hard drive which uses 6.8W.
Entrust your files to a drive that lasts
With an endurance rating of up to 220TB total bytes written, the Crucial MX300 is engineered with Micron® 3D NAND to deliver years of fast performance. The 3D NAND leverages larger NAND cells to improve performance and prolong endurance.
Protect your data with AES 256-bit hardware-based encryption, RAIN technology, Exclusive Data Defense technology, and the durability inherent in SSD design.
Keep your system cool
In addition to lower active power usage, Adaptive Thermal Protection technology dynamically adjusts storage component activity. This helps keep your system cool and minimizes the risk of damage caused by overheating.
Boost drive performance by up to 10x with Crucial Storage Executive
This downloadable tool is easy to use and helps monitor and enhance the performance of your Crucial MX300 – update to the latest firmware and enable the Momentum Cache feature in Storage Executive to instantly improve burst performance.
Micron quality — a higher level of reliability.
As a brand of Micron, one of the largest flash storage manufacturers in the world, the Crucial MX300 is backed by the same quality and innovation that has produced some of the world's most advanced memory and storage technologies. With over a thousand hours of prerelease validation testing and hundreds of SSD qualification tests, the Crucial MX300 has been thoroughly tried, tested, and proven. You'll notice the difference.
- Crucial MX300 - solid state drive - 275 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 275 GB
- Hardware Encryption
- Encryption Algorithm
- 256-bit AES
- Form Factor
- M.2 2280
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- TRIM support, hardware encryption, Error Correction Code (ECC), Adaptive Thermal Protection, Redundant Array of Independent NAND, Multistep Data Integrity Algorithm, Active Garbage Collection, Extreme Energy Efficiency technology, Data Path Protection, dynamic write acceleration, power loss prevention (PLP), Crucial Custom Firmware, Device Sleep support, S.M.A.R.T.
- 22 mm x 80 mm
- 3-year warranty
- Capacity
- 275 GB
- 256-bit AES
- Form Factor
- M.2 2280
- Interface
- SATA 6Gb/s
- 22 mm
- 80 mm
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 530 MBps (read) / 500 MBps (write)
- 4KB Random Read
- 55000 IOPS
- 4KB Random Write
- 83000 IOPS
Reliability
- MTBF
- 1,500,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s - M.2 Card
- Compatible Bay
- M.2 2280
- Software Included
- Acronis True Image HD
- UL, TUV, VCCI, C-Tick, BSMI, FCC, RoHS, KCC, WEEE, China RoHS, SATA-IO, IEEE 1667
- Limited warranty - 3 years
- 0 °C
- 70 °C
