Crucial 256MB 200SODIMM PC2700NP CL2.5
Quicklinx: 2WHDWS00 Mfr#: CT3264X335
Help your laptop perform at its best. Designed to help your laptop run faster and smoother, a Crucial memory upgrade is one of fastest, most affordable, and easiest ways to improve your system's performance. Crucial memory empowers your laptop to achieve faster application loading times, faster system responsiveness, and increased ability to multitask and handle data-intensive programs. What does this mean? Spend less time staring at loading screens and more time getting stuff done. Crucial laptop modules are rigorously tested at both the component and module levels to ensure that your memory meets the stringent compatibility and performance standards. Every module Crucial manufactures is inspected by the Systems Compatibility Group before it leaves the doors. At a fraction of the price of your laptop, an investment in Crucial memory helps your system get up to speed.
Crucial - DDR - module - 256 MB - SO-DIMM 200-pin - 333 MHz / PC2700 - unbuffered
Memory module
256 MB
Memory Type
DDR SDRAM - SO-DIMM 200-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
333 MHz (PC2700)
Unbuffered
Voltage
2.5 V
Gateway 5000633, DELL 311-1353, Panasonic CF-WMBA30256, HP F4695A, DELL 311-1681, HP 324700-001, HP 344866-001, Toshiba PA3127U-1M25, IBM 31P9830, HP 336577-001, HP 350236-001, HP 355925-001, HP 367773-001, HP DX761A, HP 285523-001, HP 317435-001, HP 371774-001, HP 381394-001, HP 336997-001, IBM 10K0030, IBM 10K0031, HP DC389A, Panasonic CF-WMBA20256, DELL A0098270, HP 407843-001, HP 383480-001, DELL A0388056, DELL A0461914, DELL A0368940, IBM 31P9831, NEC PK-UG-M036, HP EK691AA, Acer 91.43U29.001, HP 269086-B25, DELL A0150573, DELL D6G648, HP 394264-001, HP 374628-631, Ricoh 402540, NEC AN*A000009400, NEC AP*A000033700, Kingston KTC-P2800/256, Kingston KTD-INSP5150/256, Kingston KTD-INSP8200/256, Kingston KTH-ZD7000/256, Kingston KTM-TP0028/256, Kingston KTM-TP9828/256, Kingston KVR266X64SC25/256, Kingston KVR333X64SC25/256, Kingston M3264B250, Crucial MT4VDDT3264HY-335F2, Crucial MT8VDDT3264HDY-335F3, Crucial MT8VDDT3264HDY-335K1, Samsung SMM-256D266E/E, HP DC389B, Kingston KTT3614/256
256 MB
Upgrade Type
Generic
DRAM memory module
DDR SDRAM
SO-DIMM 200-pin
Speed
333 MHz (PC2700)
Non-ECC
Unbuffered
Module Configuration
32 x 64
Voltage
2.5 V
Compatible Slots
1 x memory - SO-DIMM 200-pin
