Do more. Faster. Longer.
A breakthrough in innovation, the Crucial® M550 SSD is over 20 times faster than a typical hard drive and consumes significantly less power. It enables your computer to boot up almost immediately, load files and programs almost instantly, accelerate demanding applications, and manage power more efficiently so your battery lasts longer. Backed by the most advanced feature set available - Native Write Acceleration, RAIN technology, Adaptive Thermal Protection, hardware-based encryption, and our exclusive data integrity algorithm - the Crucial M550 delivers a complete performance gain that's measured by far more than just specs.
Consistently fast speeds. No exceptions.
Every manufacturer has ideas about how to deliver better performance. Some use file compression schemes, but those don't help video, audio, or graphic files that are already compressed. Some steal system memory to improve a slow drive. The Crucial M550 treats all files the same, regardless of whether they're compressed or uncompressed, so the specs we advertise are the same ones you'll see in real world use: true 550 MB/s sequential reads across all file types.
Save on power costs and enjoy longer battery life.
Run your system longer than ever before - and use less power. Based on published specs, a common laptop hard drive uses 2.5 watts of power on an average workload, compared to 0.15 watts on the Crucial M550 (which is up to 94% more energy efficient).** In everyday terms, this means significantly more battery life and substantial savings on power costs.
Secure and protect your data - with no loss in performance.
You probably save lots of sensitive and personal information on your computer - encrypt it and keep it safe. As a self-encrypting drive, the Crucial M550 incorporates the highest level of hardware encryption into the controller, allowing the drive to operate at full speed without the performance loss associated with software-based encryption. The Crucial M550 is one of the only drives on the market to meet the rigorous requirements of TCG Opal 2.0, IEEE-1667, and Microsoft® eDrive®.
Micron® quality - a higher level of reliability.
As a brand of Micron, one of the largest flash storage manufacturers in the world, the Crucial M550 is backed by the same quality and innovation that has produced some of the world's most advanced memory and storage technologies. With over a thousand hours of prerelease validation testing and hundreds of SSD qualification tests, the Crucial M550 has been thoroughly tried, tested, and proven for the most demanding applications.
PRODUCT HIGHLIGHTS
- Load files and programs almost instantly
- Boot up almost immediately
- Accelerate demanding applications
- Download massive files in seconds rather than minutes
- Manage power so your battery lasts longer
- Encrypt and protect personal data against loss or theft
- Achieve top speeds without sacrificing reliability
- Store lots of data - available in capacities up to 1TB
Crucial® M550 1TB SATA 2.5" 7mm (with 9.5mm adapter) Internal Solid State Drive Spec
- Capacity: 1TB
- Sequential Read: 550 MB/s
- Sequential Write: 500 MB/s
- 4KB Random Read: 95,000 IOPS
- 4KB Random Write: 85,000 IOPS
- Type: 2.5-inch
- Height; 7mm (with 9.5mm adapter)
- Memory Type: Micron® 20nm MLC NAND
- Controller: Marvell® 88SS9189 with Micron® Custom Firmware
- Interface: SATA 6Gbps (SATA III)
- MTTF: 1.5 million hours
- Endurance: 72TB Total Bytes Written (TBW), equal to 40GB per day for 5 years
- Operating Temperature: 0°C to 70°C
- Hardware Encryption: AES-256 encryption engine, TCG Opal 2.0 compliant, IEEE-1667 complaint, Microsoft® eDrive® compatible
- Advanced Features: Native Write Acceleration, Redundant Array of Independent NAND, Multistep Data Integrity Algorithm, Adaptive Thermal Protection, Power Loss Protection, Data Path Protection, Active Garbage Collection, TRIM Support, Self Monitoring and Reporting Technology (SMART), Error Correction Code ECC), Device Sleep Support
- Compliance: CE, FCC, BSMI, C-Tick, VCCI, Kcc, RoHS, China RoHS, WEEE, TUV, UL, SATA-IO
Enhanced durability
With an MTBF (Mean Time Between Failures) of 1,500,000 hours, this solid state drive offers reliability and durability for users, ensuring long-term performance without the worry of frequent replacements. -
Robust compatibility
Designed to be compatible with Windows 7 and a wide range of PCs, this internal hard drive seamlessly integrates into existing systems, making it an ideal upgrade or replacement solution. -
Secure data encryption
Featuring hardware encryption, this drive provides an extra layer of security, safeguarding your data against unauthorized access and ensuring that your personal and professional information remains protected.
- Crucial M550 - solid state drive - 1 TB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 1 TB
- NAND Flash Memory Type
- 20nm multi-level cell (MLC)
- Form Factor
- 2.5" SFF
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- TRIM support, hardware encryption, Automatic Garbage Collection, sleep mode, Error Correction Code (ECC), Power Loss support, End-to-end data path protection, Adaptive Thermal Protection, Microsoft eDrive compatible, Native Write Acceleration, Redundant Array of Independent NAND, Multistep Data Integrity Algorithm, S.M.A.R.T., 256-bit AES, IEEE 1667
- 7 mm
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Capacity
- 1 TB
- Form Factor
- 2.5" SFF
- Interface
- SATA 6Gb/s
- 7 mm
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 550 MBps (read) / 500 MBps (write)
- 4KB Random Read
- 95000 IOPS
- 4KB Random Write
- 85000 IOPS
Reliability
- MTBF
- 1,500,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 2.5" SFF
- Included Accessories
- 2.5mm mounting spacer
- UL, TUV, VCCI, C-Tick, BSMI, FCC, RoHS, KCC, WEEE
- Limited warranty - 3 years
- 0 °C
- 70 °C
