Down on downtime? Count on Crucial server memory. Tested, qualified, and guaranteed-compatible, Crucial server DRAM delivers the power, reliability, and stability you can count on. Crucial robust product line includes the latest DDR3 modules and densities to meet the needs of all platforms and operating systems.
CT2KIT102472BB160B is a 16GB containing (2) 8GB DDR3 Server module that operates at speeds up to 1600 MT/s and has a CL11 latency. It is Registered with ECC Error Correction. It conforms to the industry standard RDIMM layout of 240 pins and is compatible with computers that take DDR3 RDIMM memory.
- Crucial - DDR3 - kit - 16 GB: 2 x 8 GB - DIMM 240-pin - 1600 MHz / PC3-12800 - registered
- Product Type
- Memory kit
- Capacity
- 16 GB: 2 x 8 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- Generic
- Data Integrity Check
- ECC
- Speed
- 1600 MHz (PC3-12800)
- Latency Timings
- CL11
- Dual rank, registered
- Voltage
- 1.5 V
- Limited lifetime warranty
- Capacity
- 16 GB: 2 x 8 GB
- Upgrade Type
- Generic
- DRAM memory kit
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- Latency Timings
- CL11
- ECC
- Module Configuration
- 1024 X 72
- Voltage
- 1.5 V
- Compatible Slots
- 2 x memory - DIMM 240-pin
