More speed. More bandwidth. More efficient.
In the ever-changing world of technology, any component more than half a decade old is usually in need of an update. At seven years old and counting, that's exactly the state DDR3 memory is in: computers can only do so much with it.
Since the introduction of DDR3 memory technology in 2007, processors have doubled in capability, SSDs have revolutionized throughput, and graphics cards have drastically increased frame rates, leaving memory as a limiting factor. With Crucial DDR4 Desktop Memory, crush the DDR3 memory bottleneck and unlock a new standard of performance.
CT2K8G4DFS8213 is a 16GB Kit consisting of (2) 8GB DDR4 desktop modules that operates at speeds up to 2133 MT/s and has a CL15 latency. It is an Unbuffered DIMM. It conforms to the industry standard DDR4 ECC UDIMM layout of 288 pins and is compatible with systems that take DDR4 2133MT/s UDIMM memory.
More speed
Load applications faster and run demanding programs without lag. Crucial memory modules debut faster. -
More bandwidth
Effortlessly multitask between apps and empower your system to fire on all cylinders. Crucial modules increase memory bandwidth, allowing your system to handle more data at once. Crucial memory modules are optimized for next-gen platforms, allowing you to maximize bandwidth. -
More energy efficient
Get better performance - using less power. Operating at lower power, Crucial modules consumes less voltage. Crucial memory modules also contain other efficiency features, for an amazing overall power reduction.
- Crucial - DDR4 - kit - 16 GB: 2 x 8 GB - DIMM 288-pin - 2133 MHz / PC4-17000 - unbuffered
- Product Type
- Memory kit
- Capacity
- 16 GB: 2 x 8 GB
- Memory Type
- DDR4 SDRAM - DIMM 288-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 2133 MHz (PC4-17000)
- Latency Timings
- CL15
- Dual rank, unbuffered
- Voltage
- 1.2 V
- Limited lifetime warranty
- Capacity
- 16 GB: 2 x 8 GB
- Upgrade Type
- Generic
- DRAM memory kit
- Technology
- DDR4 SDRAM
- Form Factor
- DIMM 288-pin
- Speed
- Latency Timings
- CL15
- Non-ECC
- Chips Organization
- X8
- Voltage
- 1.2 V
- Colour Category
- Green
