Crucial 16GB DDR4 3200 MHz DIMM CL22 Memory
Quicklinx: G2D7WS00 Mfr#: CT16G4DFRA32A
Type: DDR4 SDRAM
Capacity: 16GB
Connection: DIMM 288-pin
Speed: 1600MHz
Data Integrity: Non-ECC
30 In Stock
£144.39 ex VAT
£173.26 inc VAT
There's an easy cure for a slow computer: more memory. Designed to help your system run faster and smoother, Crucial Desktop Memory is one of the easiest and most affordable ways to improve your system's performance. Load programs faster. Increase responsiveness. Run data-intensive applications with ease, and increase your desktop's multitasking capabilities.
Crucial - DDR4 - module - 16 GB - DIMM 288-pin / PC4-25600 - unbuffered
Memory module
16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
3200 MT/s (PC4-25600)
Latency Timings
CL22
Unbuffered
Voltage
1.2 V
Limited lifetime warranty (Germany - 10 years)
16 GB
Upgrade Type
Generic
DRAM memory module
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL22
Non-ECC
Unbuffered
Voltage
1.2 V
Type: DDR4 SDRAM
Capacity: 16GB
Speed: 1600MHz
Registered/Buffered: Unbuffered
CAS Latency: CL22
Standard: PC4-25600
Brand: Crucial
