CRU Dataport DP10 6G SAS/SATA Black
Quicklinx: 8Z09WS00 Mfr#: 8440-6502-0500
CRU-DataPort DataPort DP10 6G 8440-6502-0500 DP10 Carrier+Frame, SAS/SATA 6GB, Black
Latest in Rugged Removable Drive Technology
  • Now supporting 6 Gbps - Backward compatible with 3 Gpbs
  • Rugged Metal Design for Ultimate Data Protection
  • Latest Version Includes Vibration Resistant Design
  • Industry Leading 5 Year Warranty!
  • Supports Enterprise Level SAS Drives
Easy Installation
  • Insert any capacity 3.5" SAS/SATA Hard Drive into the DataPort Carrier
  • Install DataPort Frame into any standard 5.25" drive bay (PC or Mac) - platform & application independent
  • Insert DataPort Carrier into compatible DataPort Frame and turn on Powered Key Lock.
Applications
  • Hard Drive Swapping
  • Physical Data Security
  • Disk-to-Disk Backup
  • Media Archiving
  • Transporting Large Files
  • PC Sharing
  • Drive Cooling/Protection
Rugged, yet affordable. Designed to fit smaller drive bay openings from PC manufacturers like Dell, IBM and HP. Supports SATA 6Gbps. Features patented drive cooling technology and 30,000+ insertion-rated connectors.
The DataPort 10 SAS/SATA is high performance removable storage in a compact enclosure designed to fit most desktop and mini-tower 5.25" bays. Engineered to support both affordable SATA and enterprise level SAS hard drives, the DataPort 10's rugged all-aluminum construction provides superior protection and cooling. The interconnect is warranted for 30k insertions and tested for 6 Gpbs full duplex operation, which delivers up to 1200MB in certain applications. When connected to a SAS host bus adaptor, the DataPort 10 SAS/SATA carrier supports both SAS and SATA HDDs. This feature allows data migration from SATA systems to SAS Workstations or Servers.
  • Rugged all metal design
  • Industry leading 5-year warranty
  • Internal cable-less design for drive connection
  • Power/drive activity LEDs for SATA 6 Gbps and SAS drives
  • Supports any capacity 3.5" SATA or SAS hard disk drive
  • Recessed connectors on receiving frame protects host connection
  • High durability Hirose connectors rated for over 30,000 insertions
  • Includes legacy to SATA power adapter cable
  • Ultra-quiet Vapo Bearing MagLev (Magnetic Levitation System) cooling fan
  • Extended fan life
  • Support for Serial ATA power; 12 volt, 5 volt and 3.3 volt requirements
  • CE compliant
  • Audible fan failure alarm
  • Supports SATA 6 Gbps features - backwards compatible to 3 Gpbs
  • Drive activity LED's
  • 6 Gbps transfer rates
  • Balanced impedance
  • Hot Swappable
  • Dimensions* 5.73" W x 7.87" L x 1.61" H (inch) 146 W x 200 L x 41 H (mm)
