Creative Vado HD Pocket Video Camcorder - Black
Quicklinx: 6Z2RWS00 Mfr#: 73VF062400012
Your baby's first steps. The family pet scampering in the garden.
Capture life's beautifully candid moments with the Vado HD (3rd Gen) - a model in the award-winning Vado series of pocket video cameras! One light touch on the touch-sensitive buttons and you can start recording instantly in high-definition quality. Lightweight and extremely compact, enjoy up to 120 minutes of widescreen HD quality video on the move. Don't cramp your style with additional camera equipment as the Vado HD (3rd Gen) comes equipped with a photo feature that lets you shoot up to 7,000 of widescreen still shots.
The video enthusiast in you will be thrilled at how much more you can achieve with the multi-function jack and the improved Vado Central 3.0 software. With the multi-function port, you can connect a handy microphone to the Vado HD (3rd Gen) for better audio recording and come playback time, simply plug in your own headphones to listen to the videos at a desired volume level. Sharing your happy times with others truly does not come easier than this!
  • Pint-sized dynamo
    Power-packed with features such as touch-sensitive buttons, 2x digital zoom, manual exposure adjustments, and motion detection, the Vado HD (3rd Gen) is a must-have for those capturing action on the go.
  • One click to instant gratification
    With the handy Vado HD (3rd Gen), you won't have to worry about missing any important action again. Record important moments instantly with the one-click recording button and at a quick switch, change to photo mode to capture picture-perfect stills!
  • Significant moments in high-definition quality
    Enjoy 2 hours of HD quality footage at a video resolution of up to 1280 x 720p. Alternatively, you can snap up to 7,000 picture-perfect still photos of your favorite camera subject.
  • Multiple connectivity options
    The Vado HD (3rd Gen) is equipped with a multi-function port that gives you the flexibility to do more with your pocket camcorder. Plug in a stereo microphone for enhanced audio recording - an especially handy feature in news reporting, concert filming and more.
  • Watch it on the big screen
    Connect your Vado HD (3rd Gen) to a HDTV via a HDMI cable to enjoy big screen viewing and your videos in 720p HD quality. No need to hit the cinemas for the best theater experience.
  • Wider scenes, more action
    Capture wider scenes and more action in your videos and photos with the wide-angle lens. You can also get a close-up of the action with the 2x digital zoom feature.
  • Built-in flexible USB connector
    Charge your pocket video camera easily via the built-in USB connector. Absolutely no need for any additional cables!
Creative Vado Pocket Video Cam HD (3rd Gen) - camcorder - internal flash memory
Camcorder - 720p
Media Type
Internal flash memory
Internal Storage
4 GB flash
Lens System
3.79 mm f/2.0
Digital Zoom
2x
Display
LCD display - 2"
Supported Battery
Li-ion rechargeable battery (included)
Composite video/audio, HDMI
5.8 cm x 1.6 cm x 9.9 cm
93 g
Camcorder - 720p
Enclosure Colour
Camcorder Type
Consumer
Sensor Qty
1 CMOS
Widescreen Video Capture
Camcorder Media Type
Optical Sensor Type
CMOS
Digital Zoom
2x
Services and Applications
YouTube capture mode
Digital Video Format
H.264
Image Recording Format
JPEG
Exposure & White Balance
Exposure Modes
Programme, automatic
Lens System
3.79 f/2.0
Additional Features
Low Lux / Night Mode
Additional Features
Built-in speaker, auto power save, date/time stamp, USB charging, Motion Detection Technology
Display
2" LCD display
Display Format
640 x 240
Display Form Factor
Built-in
Connector Type
USB , Composite video/audio output , HDMI output , Microphone , Headphones
Software
Software
Drivers & Utilities, Creative Vado Central
USB extension cable
Battery Type
Lithium Ion - manufacturer-specific
Run Time (Up To)
2 hour(s)
Details
Memory / Storage
Internal Storage
4 GB flash
Memory Card
4 GB
Image Storage
JPEG 1280 x 720
Video Capture
H.264 - 1280 x 720 - 30 fps , H.264 - 640 x 480 - 30 fps
5.8 cm
1.6 cm
9.9 cm
93 g
