2.1 Wireless Speaker System with NFC
Riding on the technology and legacy of our popular, award-winning GigaWorks T3, the Creative T4 Wireless Signature Series continues to fulfill the promise of premium audio quality and convenience for all your entertainment needs, while giving you now the privilege of enjoying all this wirelessly too. It features sleek satellites with audiophile-grade aluminum drivers and a high-performance SLAM® subwoofer.
Indulge your senses
A major part of getting the best sensory experience out of your entertainment lies in the quality of your audio. The Creative T4 Wireless is specially engineered and designed to meet - and perhaps even go beyond - all your entertainment audio needs.
For the movie buff
Feel the excitement and action of your movies as you immerse yourself in the realistic audio playback of the movie, and without compromising on the clarity of the dialog
Quality wireless audio
The Creative T4 Wireless is equipped with aptX® and AAC high-definition codecs, giving you high-resolution wireless Bluetooth® audio that sounds as good as audio from a wired connection.
Awesome mids and highs
The audiophile-grade aluminium driver in each satellite delivers full midrange and ultra-clear highs, giving you clear, crisp audio.
Deep, tight bass
The powerful yet compact Creative SLAM™ (Symmetrically Loaded Acoustic Module) subwoofer is professionally engineered and tuned to perfection to bring you realistic heart-thumping bass for a completely engaging gaming or movie experience.
Freedom without compromise
Bluetooth wireless connectivity gives you the freedom and convenience to move around your room with your smart device as you're not tied down by any wires.1 And with aptX, you're assured of uncompromised audio quality.
Indulge your senses
A major part of getting the best sensory experience out of your entertainment lies in the quality of your audio. The Creative T4 Wireless is specially engineered and designed to meet - and perhaps even go beyond - all your entertainment audio needs. -
For the movie buff
Feel the excitement and action of your movies as you immerse yourself in the realistic audio playback of the movie, and without compromising on the clarity of the dialog. -
The Creative T4 Wireless is equipped with aptX and AAC high-definition codecs, giving you high-resolution wireless Bluetooth audio that sounds as good as audio from a wired connection. -
The audiophile-grade aluminum driver in each satellite delivers full midrange and ultra-clear highs, giving you clear, crisp audio. -
Deep, tight bass
The powerful yet compact Creative SLAM (Symmetrically Loaded Acoustic Module) subwoofer is professionally engineered and tuned to perfection to bring you realistic heart-thumping bass for a completely engaging gaming or movie experience. -
Bluetooth wireless connectivity gives you the freedom and convenience to move around your room with your smart device as you're not tied down by any wires. And with aptX, you're assured of uncompromised audio quality. -
Switch to private listening
For late-night gaming or movie-watching, there's no need to worry about waking up the household. The Creative T4 Wireless' Audio Control Pod is integrated with a dedicated headphone jack so that you can conveniently plug in your headphones when the need arises. -
Get the bass you want
Increase or reduce the desired bass level by simply using the adjustment knob located on the subwoofer. -
Infrared remote
The IR remote lets you take control of your speakers without you having to leave the couch! You can perform source selection (Bluetooth, aux-in and optical), turn the speaker on or off, adjust the volume and even control music playback. -
Made for big sound
The Creative T4 Wireless' satellites are designed to deliver powerful audio despite their small size. The small footprint makes it easy for you to position them wherever you want, while saving space on your desktop or living room table. The satellites can also be wall-mounted, making them ideal as TV speakers in the living room.
- Creative T4 Wireless - speaker system - wireless
- Product Type
- Speaker system - 2.1-channel
- System Components
- 2 speakers, subwoofer
- Speaker Type
- Active
- Amplifier
- Integrated
- Bluetooth, NFC
- Audio Formats
- AAC, apt-X
- Built-in Decoders
- SBC decoder, aptX
- Product Type
Speaker System
- System Components
- Speaker Type
- Active
- Amplifier
- Integrated
- Bluetooth 3.0, Near Field Communication (NFC)
- Bluetooth Profiles
- Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Transmission Range
- 10 m
- Built-in Decoders
- SBC decoder, aptX
- Audio Formats
- AAC, apt-X
- Additional Features
- Symmetrically Loaded Acoustic Module (SLAM) technology
- Connector Type
- Audio line-in (RCA x 2) , Headphones (mini-phone stereo 3.5 mm) , Digital audio input (optical) (TOS Link)
- Included Accessories
- Power adapter, RCA to 3.5 mm adapter cable, IR remote control, cable remote control
- Power Source
- AC power adapter
- Dimensions (WxDxH) / Weight Details
- Satellite speaker: 8.5 cm x 9 cm x 15 cm / 465 g , Subwoofer: 23.5 cm x 29 cm x 21.5 cm / 5.94 kg
