Creative T30 Wireless 2.0 Speakers with NFC
Quicklinx: 8ZTTWS00 Mfr#: 51MF1655AA004
2.0 Wireless Speakers with NFC
Creative T30 Wireless builds on the technology of our GigaWorks T20 Series, featuring custom-made silk dome tweeters and woven glass-fiber cone drivers for excellent dynamic response, and BasXport® technology for high-output bass. It now comes with Bluetooth® capability and aptX® audio codec support to give you high-quality wireless playback and is further equipped with NFC for easy, one-touch pairing.
Tap and play
If your device has Near Field Communication (NFC) capabilities, simply tap it on the speakers' NFC receptor for easy, fuss-free pairing!
No more messy wires
Stream audio wirelessly from any compatible stereo Bluetooth smart device1 to the speakers from a range of up to 10 meters.
High-quality wireless audio
With the speakers' support for the aptX audio codec, you are set to enjoy high-resolution wireless Bluetooth audio that sounds as good as audio via a wired connection.
Primed for smooth highs and full-bodied midrange
Creative T30 Wireless features a 2-Driver Design - the custom-made silk dome tweeters give you silky smooth highs, while the woven glass-fibre cone drivers deliver natural and accurate full-bodied midrange. They work in tandem to produce an excellent dynamic response.
Get high-output bass
With the built-in BasXPort™ technology, each speaker is integrated with a large port tube to channel sound waves from the inner chamber of the satellite to the soundstage, giving you high-output bass.
Perfect anywhere
Creative T30 Wireless features an integrated line-in jack for connection to other analog audio devices, and a dedicated headphones jack for private listening. An RCA-to-3.5mm adapter is also included, giving you more connectivity options.
  • Tap and play
  • No more messy wires
    Stream audio wirelessly from any compatible stereo Bluetooth smart device to the speakers from a range of up to 10 meters.
  • High-quality wireless audio
  • Primed for smooth highs and full-bodied midrange
    Creative T30 Wireless features a 2-driver design - the custom-made silk dome tweeters give you silky smooth highs, while the woven glass-fiber cone drivers deliver natural and accurate full-bodied midrange. They work in tandem to produce an excellent dynamic response.
  • Get high-output bass
    With the built-in BasXPort technology, each speaker is integrated with a large port tube to channel sound waves from the inner chamber of the satellite to the soundstage, giving you high-output bass.
  • Perfect anywhere
    Creative T30 Wireless features an integrated line-in jack for connection to other analog audio devices, and a dedicated headphones jack for private listening. An RCA-to-3.5 mm adapter is also included, giving you more connectivity options.
  • Face the music
    Each of the speaker's face panel is tilted at a 10° angle for optimal audio projection directly at the listener. The Creative T30 Wireless is the perfect addition to any room.
Creative T30 Wireless - speakers - wireless
Speakers
System Components
2 speakers
Enclosure Design
Bass reflex
Speaker Type
2-way - active
Amplifier
Integrated
Bluetooth, NFC
Audio Formats
Apt-X
Speaker System Details
2 x speaker
Gloss piano black
Built-in Decoders
SBC decoder, aptX
Speakers
Enclosure Colour
Gloss piano black
Enclosure Design
Bass reflex
Speaker System
System Components
2 speakers
Speaker Type
2-way - active
Amplifier
Integrated
Bluetooth 3.0, Near Field Communication (NFC)
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP)
Transmission Range
10 m
Built-in Decoders
SBC decoder, aptX
Audio Formats
Apt-X
Controls
Power on/off, volume, treble, bass
Speakers Included
2 x speaker - 2-way
Driver Details
Speaker: mid-range driver - woven fibreglass , Speaker: tweeter driver - silk - Soft Dome
Connector Type
Audio line-in (mini-phone stereo 3.5 mm) , Headphones (mini-phone stereo 3.5 mm)
Power adapter, audio adapter
Power Source
AC power adapter
Dimensions (WxDxH) / Weight Details
Left channel speaker: 8.7 cm x 17.5 cm x 23 cm / 850 g , Right channel speaker: 8.7 cm x 18 cm x 23 cm / 983 g
