Creative SoundBlaster X-Fi Titanium HD
Quicklinx: 75RZWS00 Mfr#: 70SB127000001
The Sound Blaster X-Fi Titanium HD provides the highest quality audio playback of any other sound card Creative has ever introduced. This sound card includes THX TruStudio PC audio technology, bringing together two of the most respected names in sound quality to provide an unparalleled audio experience on the PC. The Sound Blaster X-Fi Titanium HD features audiophile-grade components for high-quality playback of music, games and movies, including 122db SNR Digital-to-Analog Converters (DACs), the highest signal-to-noise ratio sound card ever produced by Creative. Replaceable OP-amps provide the flexibility to further customize your audio experience through different sound coloration. If you are serious about how your PC sounds, this is the ultimate Sound Blaster experience.
Rated 10/10 by HardwareHeaven!
"...Without doubt the best audio card Creative have ever produced. The X-Fi Titanium HD passes the most important test with flying colours; its exceptional quality of audio draws you in and makes music more enjoyable. The end result is countless hours lost as we listen to "just one more track" to see how it should have always sounded..."
  • Premium sound blaster quality
    Featuring High-Fidelity audio performance with the Digital-Analog (D/A), Analog-Digital (A/D) converters, together with a signal-to-noise ratio (SNR) of 122dB with 0.001% (THD) distortion, the Sound Blaster X-Fi Titanium HD is the ideal choice for the demanding audiophile.
  • Audiophile components
    The Sound Blaster X-Fi Titanium HD features high quality components offering audiophile-grade performance, designed to eliminate noise, while dramatically improving sound field dynamics in the high and mid tones.
  • Superior headphone experience
    Enjoy pristine audio in private anywhere with the superlative headphone output featuring an amazing 115dB, 24-bit/96kHz support in High-Definition (HD) quality sound for original playback.
  • Personalize your sound with upgradeable components
    For the discerning music listener, you can personalize your listening experience with the swappable OP-amp sockets on the sound card to tailor sound to the way you want it.
  • THX TruStudio PC for unprecedented audio realism
    The ground-breaking THX TruStudio PC sound effects will transform your experience into a true High-Definition (HD) multimedia emotional journey.
  • Hardware accelerated EAX 5.0 for ultimate gaming audio
    Hardware-powered 3D positional audio and EAX 5.0 effects provide stunning audio realism over both headphones and speakers without affecting your frame-rates.
  • Pristine audio recordings with ultra low latency
    ASIO recording support with latency as low as one millisecond and minimal CPU load for precise audio recordings.
  • Immersive digital home entertainment
    Dolby Digital and DTS encoding enable a simple one-step single-cable connection to home entertainment systems with included optical cables, for compelling surround sound.
Creative Sound Blaster X-Fi Titanium HD - sound card
Sound card
Enclosure Type
Internal
Interface Type
PCI Express x1
Signal Processor
Creative X-Fi Xtreme Fidelity
Sound Output Mode
Stereo
DAC Resolution
24-bit
Sample Rate
192 kHz (max)
Signal-To-Noise Ratio
122 dB
Microsoft Certification
Compatible with Windows 7
Microsoft Windows Vista (32/64 bits) SP1, Microsoft Windows 7 (32/64 bits)
Sound card
Internal
Interface Type
PCI Express x1
Processor / Memory
Signal Processor
Audio Output
Sound Output Mode
Stereo
DAC Resolution
24-bit
Sample Rate
192 kHz (max)
122 dB
ASIO 2.0, Dolby Digital Live, EAX 5.0, DTS Connect
Audio Modes
Playback: 24-bit 96 kHz stereo - 122 dB , Record: 24-bit 96 kHz - 118 dB
1 x microphone - mini-phone 3.5 mm , 1 x headphones - mini-phone stereo 3.5 mm , 1 x SPDIF input - TOSLINK , 1 x SPDIF output - TOSLINK
Software
Drivers & Utilities, Creative Console Launcher, Creative Mode Switcher, Creative Volume Panel, Creative ALchemy
Additional Requirements
CD-ROM
System Requirements Details
Windows 7/Vista - Core 2 Duo - 1.86 GHz - RAM 1 GB - HD 600 MB
