If you're a serious gamer and you need exceptional audio without breaking the bank, the Sound Blaster Tactic3D Rage USB V2.0 Gaming Headset is just what you need. With powerful 50mm drivers and SBX Pro Studio technologies, it delivers superior gaming audio that's backed by decades of legendary Sound Blaster expertise.
Hear them before they hear you
This proprietary technology allows you to hear your enemies from further away in your game, giving you a distinct tactical advantage in combat. -
Works with Playstation 4
Welcome the arrival of a generation of console gaming! Get yourself ready to experience some unparalleled realistic gaming action by gearing up with the Sound Blaster Tactic3D Rage USB V2.0, compatible with Playstation 4 gaming console via USB for awesome virtual surround sound stage in combat. -
Affordable USB gaming headset
Enjoy superior, uncompressed audio for your games and entertainment that's affordable, without any compromise in audio quality. -
16 million-color illuminated ear cups
Put on a color that fits your style or mood. Choose from a dizzying 16 million colors to complement your team, rig, or aura. -
50mm FullSpectrum drivers
Experience a high-powered, no-holds-barred 3D gaming audio experience with massive bass and detailed highs. -
Experience 3D surround sound
Free yourself from the limits of physical 7.1 audio. Immerse yourself right in the middle of your game. -
High-quality USB audio cable
Spend more time gaming instead of being in a tangled mess. The high quality USB audio cable provides excellent flexibility while minimizing unwieldy tangles. -
Accessible on-ear audio controls
Easily adjust your game volume or mute your microphone on the fly. With the rotary volume control dial, you can make faster, more precise volume adjustments. -
Put on a color that fits your style or mood. Choose from a dizzying 16 million colors to complement your gaming team, rig, or aura. -
Take on a persona
With VoiceFX, you can match your voice to your game avatar, be it an orc, elf or alien infiltrator. Dont just play your avatar, BE your avatar. -
SBX Pro Studio sound technologies create unprecedented levels of audio realism, including stunning 3D surround effects for your speakers and headsets.
- Creative Sound Blaster Tactic3D Rage USB V2.0 - headset
- Product Type
- Headset - 7.1 channel - wired
- Recommended Use
- Game console, computer
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wired
- Sound Output Mode
- Surround Sound
- Sound Effects
- 3D Surround Sound
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 102 dB/mW
- Impedance
- 32 Ohm
- Microphone
- Detachable - boom
- Microphone Technology
- Electret condenser
- Controls
- Volume
- Microsoft Certification
- Compatible with Windows 7
- 2-year warranty
- Product Type
- Recommended Use
Audio Output
- Full size
- Wired
- Sound Output Mode
- Surround Sound
- Sound Effects
- 3D Surround Sound
- 20 - 20000 Hz
- Sensitivity
- 102 dB/mW
- Impedance
- 32 Ohm
- Diaphragm
- 50 mm
- Magnet Material
- Neodymium
Microphone
- Boom
- Sensitivity
- -40 dBV/Pascal
- Impedance
- 2.2 kOhm
- 100 - 6500 Hz
Remote Control
- Controls
- Volume
- Connector Type
- USB (4 PIN USB Type A) , Headset (mini-phone stereo 3.5 mm)
- Cable Details
- Micro-USB to USB cable - 1.8 m
- Limited warranty - 2 years
