Evolve your game with immersive 3D Audio, thanks to THX TruStudio Pro Technology
Experience the evolution of 3D gaming audio with the Sound Blaster Tactic3D Alpha gaming headset. Acoustically optimized 40mm drivers combine with THX TruStudio Pro technology to transform everyday audio into a mind-blowing cinematic experience. The dual mode design allows you to connect via standard mini jacks or use the Dual Mode adapter to connect to your PC or Mac's USB port for the full THX TruStudio Pro experience.
Dual Mode - Analog or USB, your choice!
Connect the headset via 3.5mm minijacks to your Sound Blaster sound system, onboard audio or MP3 player. Alternatively, use the THX TruStudio Pro Dual Mode USB Adapter to connect to your PC or Mac via USB.
THX TruStudio Pro Surround™ audio immerses you in the game so you hear sounds clearly from the front, back, around, above and below. Only THX TruStudio Pro Surround delivers truly 3D audio surround effects to give you the gaming advantage you need.
Tailor your sound with touch screen controls
Customizable TacticControl™ driver interface optimized with Live!Touch™ for touchscreen controls under Windows 7 operating system gives you full control over every nuance of the THX TruStudio Pro audio suite as well as custom graphic equalizer and VoiceFX controls.
Customise and share optimized audio settings
Customize your own TacticProfile™ EQ and audio profiles, and then export and share them with other gamers. You can also use pre-configured audio settings from world-renowned gamers such as Fatal1ty, compLexity and Team Dignitas.
Have fun with your gaming voice
Morph your voice into different in-game characters with VoiceFX technology and restore surround audio to your Windows XP games in Windows 7 with Creative ALchemy.
Effortless communication with your team-mates
Use the Sound Blaster Tactic3D Alpha headset with your favorite gaming communications software such as Ventrilo or TeamSpeak.
Box Contents
-Sound Blaster Tactic3D Alpha with detachable microphone and in-line volume control
-THX TruStudio Pro Dual Mode™ USB adapter
-Quick Start Guide
Software:
-TacticControl™ Control Panel optimized with LiveTouch™
-User Guide
Dual mode - analog or USB, your choice
Connect the headset via 3.5mm mini jacks to your Sound Blaster sound system, onboard audio or MP3 player. Alternatively, use the THX TruStudio Pro Dual Mode USB adapter to connect to your PC or Mac via USB. -
THX TruStudio Pro Surround audio immerses you in the game so you hear sounds clearly from the front, back, around, above and below. THX TruStudio Pro Surround delivers truly 3D audio surround effects to give you the gaming advantage you need. -
Customizable TacticControl driver interface optimized with Live! Touch for touch-screen controls under Windows 7 operating system gives you full control over every nuance of the THX TruStudio Pro audio suite as well as custom graphic equalizer and VoiceFX controls. -
Customize and share optimized audio settings
Customize your own TacticProfile EQ and audio profiles, and then export and share them with other gamers. You can also use pre-configured audio settings from world-renowned gamers such as Fatal1ty, compLexity and Team Dignitas.
- Creative Sound Blaster Tactic3D Alpha - headset
- Product Type
- Headset - wired
- Recommended Use
- Computer
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 100 dB/mW
- Impedance
- 32 Ohm
- Microphone
- Detachable - boom
- Controls
- Volume
- Product Type
- Headset - wired
- Recommended Use
- Computer
Audio Output
- Full size
- Wired
- Sound Output Mode
- Stereo
- 20 - 20000 Hz
- Sensitivity
- 100 dB/mW
- Impedance
- 32 Ohm
- Diaphragm
- 40 mm
- Magnet Material
- Neodymium
Microphone
- Boom
- Sensitivity
- -41 dBV/Pascal
- Impedance
- 2.2 kOhm
- 80 - 14000 Hz
Remote Control
- Controls
- Volume
- Connector Type
- 2 x headset (mini-phone stereo 3.5 mm) , USB (4 PIN USB Type A)
- Cable Details
- Headset cable , Audio / USB adapter
