The Sound Blaster Roar 2 is specially designed for people who not only appreciate portable speakers for their audio performance, but also for their looks. Wrapped in a stylish sleek housing, the Sound Blaster Roar 2 exudes understated sophistication of a well-designed audio instrument that continues to impress - whether it's in the office, at home or a party.
Dual orientation
Whether it's horizontally or vertically placed, the Sound Blaster Roar 2 tunes to your acoustic preference. A horizontal placement lets you experience room-filling and balanced audio. Alternatively, a vertical placement has a smaller footprint but it produces louder and more directed audio and brings the controls on the back panel closer to you. The Sound Blaster Roar 2 is meant to have dual orientation, with your convenience in mind. -
Bi-amplified design
Most portable speakers utilize a single amplifier to reproduce the entire audio spectrum. With a single amplifier design, much demand goes into reproducing the lows and mids, which compromises the delivery of the highs. On the other hand, the Sound Blaster Roar 2 utilizes two amplifiers - one dedicated to driving lows and mids, and another is solely dedicated to deliver the high frequencies. This allows the speaker to produce uncompromisingly clear, high definition, and well-balanced music. The top-firing bass and mid-level driver is also laid horizontally, reducing the speaker's center of gravity, thus stabilizing it. -
Same five high-performance speaker drivers
Despite having a smaller enclosure, the Sound Blaster Roar 2 houses the same premium five drivers as the Sound Blaster Roar. From the two far-field tweeters, a powerful subwoofer and two unobstructed passive radiators, which are beautifully machine-finished, every element of the design is thoughtfully considered to enhance your audio experience. -
Clean, powerful bass
The active 2.5? driver pumps out impressive mids and lows. Directing the audio upwards also stabilizes the speaker and provides for a wider soundstage that does not require the listener to be situated in the audio sweet spot. -
Compact, powerful, high frequency drivers
Durable and lightweight high-frequency drivers deliver balanced highs. These dual 1.5" premium drivers are also designed to provide far-field high-frequency dispersion.
- Creative Sound Blaster Roar 2 - speaker - for portable use - wireless
- Product Type
- Speaker - for portable use
- Media Content Source
- Flash memory card
- Digital recorder
- Speaker Type
- Active
- Amplifier
- Integrated
- Bluetooth, NFC
- Audio Formats
- WAV, WMA, AAC, MP3, apt-X
- Speaker Details
- Speaker - stereo x 2 - active , Speaker - subwoofer - active
- White
- Built-in Decoders
- SBC decoder, aptX
- Power Options
- USB charging
- Battery
- Speaker battery rechargeable - Lithium Ion
- 18.8 cm x 10.9 cm x 5.1 cm
- 1 kg
- Product Type
- Digital recorder
- Flash memory card
- Hands-Free Function
- Enclosure Colour
- White
Speaker System
- Speaker Type
- Active
- Amplifier
- Integrated
- Bluetooth 3.0, Near Field Communication (NFC)
- Bluetooth Profiles
- Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Transmission Range
- 10 m
- Built-in Decoders
- SBC decoder, aptX
- Audio Formats
- Controls
- Power on/off, volume, call answer
- Interface Type
- USB
- Additional Features
- Bi-amplified
Speaker System Details
- Speaker Details
- Driver Details
- Speaker: 2 x tweeter driver - 1.5" , Speaker: subwoofer driver - 2.5" , Speaker: 2 x Passive Radiator - side-firing
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm) , DC power output (4 PIN USB Type A) , USB
- Included Accessories
- Power adapter, micro-USB cable
- Power Source
- USB, battery
- Options
- USB charging
- Rechargeable - Lithium Ion
- Capacity (Ah)
- 6000 mAh
- Run Time (Up To)
- 8 hour(s)
- 18.8 cm
- 10.9 cm
- 5.1 cm
- 1 kg
