Creative Sound Blaster E1 Headphoner Amp
Quicklinx: B6HMWS00 Mfr#: 70SB160000001
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
Sound Blaster E1 is a portable and powerful headphone amplifier with support for studio-quality 600 ohm headphones, audio playback and two headphone jacks for easy music sharing with your friends.
Tired of having to choose specific headphones impedances to match your setup? The Sound Blaster E1 supports headphones with impedances of up to 600 ohms. This means you can match just about any headphones with it. Enjoy a level of audio detail & resolution previously unreachable.
Sound Blaster E1 is small and light. This means it can be easily carried around in a bag or a pocket, or clipped onto clothing. No longer will you have to haul a headphone amplifier the size of a brick to enjoy better audio.
  • Experience HD audio on the go
  • Enjoy studio quality audio
  • High fidelity audio, real high
    Enjoy your music on the go with jaw-dropping audio fidelity of 106 dB Signal-to-Noise Ratio (SNR). Hear more music, not noise.
  • For those long nights
    Sound Blaster E1 performs up to 25-hours per charge. That's more than a whole day of high fidelity continuous playback!
  • Lighter, always better
  • Share your music, the better way
    Sharing your music is easy with the Sound Blaster E1 which comes with two headphone output jacks! Unlike other shared outputs, the Sound Blaster E1 does not compromise on audio fidelity, so the quality remains the same even when powering two discrete outputs!
  • Personalize your audio experience
    With SBX Pro Studio technology and connected to PCs and Macs, you can further adjust what you love to listen, to your individual taste.
  • Clear voice conversations with CrystalVoice technology
    The built-in microphone provides the additional benefit of using your normal headphones for conversations over the phone. When connected to PCs and Macs via USB, you can activate the CrystalVoice technology, a suite of enhancements that reduces noise and provides for clearer conversations.
Creative Sound Blaster E1 - sound card
Sound card
Enclosure Type
External
Sound Output Mode
Stereo
Signal-To-Noise Ratio
106 dB
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Apple MacOS X 10.6.8 or later, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits)
Sound card
External
Audio Output
Sound Output Mode
Stereo
106 dB
Headphone Amplifier
1 x audio line-in - mini-phone 3.5 mm 4-pole , 1 x headphones - mini-phone stereo 3.5 mm , 1 x microphone - mini-phone stereo 3.5 mm
1 x audio cable , 1 x USB cable
