The ideal speaker system for wireless music listening
Enjoy your music wirelessly with the Creative T3150 Wireless 2.1 speaker system. Equipped with Bluetooth® wireless technology, it works with compatible Bluetooth-enabled stereo devices such as mobile phones and laptops, providing additional connectivity on top of the usual wired connection. The satellites feature Creative's Image Focusing Plate (IFP) design that facilitates a wide acoustic sweet spot with improved sonic directivity to the listening area, giving music more focus and preserving tonal accuracy. The powerful, custom-tuned down-firing subwoofer gives your music a boost that is sure to delight your senses. The speaker system, which includes a convenient wired remote control, makes a perfect addition to any study or bedroom.
Pair with any compatible stereo Bluetooth device
Wirelessly stream music from any compatible stereo Bluetooth device, such as your mobile devices or notebook, from a range of up to 10 meters1 from the speaker.
Enjoy natural sounding audio
The Creative Image Focusing Plate (IFP) design features an extended flare surrounding the satellite driver to provide an even wider acoustic sweet spot. This improves sonic directivity to the listening area, giving music more focus while preserving tonal accuracy.
Superb bass
Enjoy superb bass from the custom-tuned, down-firing subwoofer with a large flared port tube that will give you just the right 'oomph' you'll love in your music.
Easy access to controls
The power and volume control are integrated into one independent wired remote control for your convenience and ease of use.
Wirelessly stream music from any compatible stereo Bluetooth device, such as your mobile devices or notebook, from a range of up to 10 meters from the speaker. -
The Creative Image Focusing Plate (IFP) design features an extended flare surrounding the satellite driver to provide an even wider acoustic sweet spot. This improves sonic directivity to the listening area, giving music more focus while preserving tonal accuracy. -
Superb bass
Enjoy superb bass from the custom-tuned, down-firing subwoofer with a large flared port tube that will give you just the right 'oomph' you'll love in your music. -
- Creative T3150 Wireless - speaker system - for PC - wireless
- Product Type
- Speaker system - for PC - 2.1-channel
- System Components
- 2 speakers, subwoofer
- Speaker Type
- Active
- Amplifier
- Integrated
- Bluetooth
- Speaker System Details
- 2 x satellite speaker , 1 x subwoofer
- Product Type
Speaker System
- System Components
- Speaker Type
- Active
- Amplifier
- Integrated
- Bluetooth 2.1 EDR
- Bluetooth Profiles
- Advanced Audio Distribution Profile (A2DP)
- Transmission Range
- 10 m
- Speakers Included
- 2 x satellite speaker - wired , 1 x subwoofer - wired
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm)
- Power Source
- AC power adapter
- Dimensions (WxDxH) / Weight Details
- Satellite speaker: 7.5 cm x 9 cm x 15 cm / 230 g , Subwoofer: 18.4 cm x 19 cm x 22.5 cm / 1.9 kg
