Creative Inspire T3130 - 2.1-channel PC multimedia speaker system - 25 Watt (Total) - Black
Quicklinx: 67J1WS00 Mfr#: 51MF0395AA003
With its stylish design and quality performance, this 2.1 speaker system is the perfect audio choice for a step up from ordinary entertainment
This 2.1 speaker system features the Creative Image Focusing Plate (IFP) design which improves sonic directivity and imaging while preserving tonal accuracy. You can also fine-tune your audio preferences by accessing the wired remote control and bass control easily on the subwoofer. Conveniently connect these sleek speakers to your PC, notebook or MP3 player, and experience great audio immediately! For everyday music listening at an amazing value, the Inspire T3130 is your ideal companion.
Creative Image Focusing Plate design
The system's Creative IFP design features a flare surrounding the satellite driver to improve sonic directivity and imaging to the listening area, giving music more focus while preserving tonal accuracy.
Powerful subwoofer
Feel clean, explosive bass from the subwoofer, thanks to its large flared port tube design. You can even set your desired bass level simply by adjusting the conveniently located knob.
Wired remote control
Enjoy the convenience of powering on/off the speaker system and adjusting its volume with the included wired remote. Place it within convenient reach on your desktop!
Magnetically-shielded speakers
Place these magnetically-shielded speakers anywhere you want, even near notebooks or LCD/CRT monitors, as they wouldn't cause any image distortion or interference. Their small footprint also optimizes space on your desktop, reducing unnecessary clutter.
Box Contents
-Two satellite speakers
-One subwoofer
-Quick Start Guide
-Warranty/Technical Support leaflet
  • Creative Image Focusing Plate design
  • Powerful subwoofer
  • Magnetically-shielded speakers
Creative Inspire T3130 - speaker system - for PC
Speaker system - for PC - 2.1-channel
System Components
2 speakers, subwoofer
Speaker Type
Active
Nominal Output Power (Total)
25 Watt
Frequency Response
40 - 20000 Hz
Amplifier
Integrated
Speaker System Details
2 x satellite speaker 5 Watt , 1 x subwoofer 15 Watt
1-year warranty
Enclosure Colour
Speaker System
System Components
Speaker Type
Active
Audio System Continuous Power (Total)
25 Watt
Frequency Response
40 - 20000 Hz
Signal-To-Noise Ratio
75 dB
Magnetic Shield
Amplifier
Integrated
Controls
Volume, bass
Speakers Included
2 x satellite speaker - 5 Watt - wired , 1 x subwoofer - 15 Watt - wired
Power adapter, remote control
Remote Control
Remote control - cable
Power adapter - external
Power Source
AC power adapter
Dimensions (WxDxH) / Weight Details
Satellite speaker: 7.5 cm x 9 cm x 15 cm / 355 g , Subwoofer: 16 cm x 22.7 cm x 21.3 cm / 2.7 kg
Limited warranty - 1 year
