With its stylish design and quality performance, this 2.1 speaker system is the perfect audio choice for a step up from ordinary entertainment
This 2.1 speaker system features the Creative Image Focusing Plate (IFP) design which improves sonic directivity and imaging while preserving tonal accuracy. You can also fine-tune your audio preferences by accessing the wired remote control and bass control easily on the subwoofer. Conveniently connect these sleek speakers to your PC, notebook or MP3 player, and experience great audio immediately! For everyday music listening at an amazing value, the Inspire T3130 is your ideal companion.
Creative Image Focusing Plate design
The system's Creative IFP design features a flare surrounding the satellite driver to improve sonic directivity and imaging to the listening area, giving music more focus while preserving tonal accuracy.
Powerful subwoofer
Feel clean, explosive bass from the subwoofer, thanks to its large flared port tube design. You can even set your desired bass level simply by adjusting the conveniently located knob.
Wired remote control
Enjoy the convenience of powering on/off the speaker system and adjusting its volume with the included wired remote. Place it within convenient reach on your desktop!
Magnetically-shielded speakers
Place these magnetically-shielded speakers anywhere you want, even near notebooks or LCD/CRT monitors, as they wouldn't cause any image distortion or interference. Their small footprint also optimizes space on your desktop, reducing unnecessary clutter.
Box Contents
-Two satellite speakers
-One subwoofer
-Quick Start Guide
-Warranty/Technical Support leaflet
The system's Creative IFP design features a flare surrounding the satellite driver to improve sonic directivity and imaging to the listening area, giving music more focus while preserving tonal accuracy. -
Powerful subwoofer
Feel clean, explosive bass from the subwoofer, thanks to its large flared port tube design. You can even set your desired bass level simply by adjusting the conveniently located knob. -
- Creative Inspire T3130 - speaker system - for PC
- Product Type
- Speaker system - for PC - 2.1-channel
- System Components
- 2 speakers, subwoofer
- Speaker Type
- Active
- Nominal Output Power (Total)
- 25 Watt
- Frequency Response
- 40 - 20000 Hz
- Amplifier
- Integrated
- Speaker System Details
- 2 x satellite speaker 5 Watt , 1 x subwoofer 15 Watt
- Black
- 1-year warranty
- Product Type
- Enclosure Colour
- Black
Speaker System
- System Components
- Speaker Type
- Active
- Audio System Continuous Power (Total)
- 25 Watt
- 40 - 20000 Hz
- Signal-To-Noise Ratio
- 75 dB
- Magnetic Shield
- Amplifier
- Integrated
- Controls
- Volume, bass
- Speakers Included
- 2 x satellite speaker - 5 Watt - wired , 1 x subwoofer - 15 Watt - wired
- Included Accessories
- Power adapter, remote control
- Remote Control
- Remote control - cable
- Power Device
- Power adapter - external
- Power Source
- AC power adapter
- Dimensions (WxDxH) / Weight Details
- Satellite speaker: 7.5 cm x 9 cm x 15 cm / 355 g , Subwoofer: 16 cm x 22.7 cm x 21.3 cm / 2.7 kg
- Limited warranty - 1 year
