Quality wireless desktop speakers
Give your desktop PC a lease of life with the Creative T12 Wireless 2.0 speaker system. Excellent aural dynamics are a given with this two-piece speaker system thanks to the high-performance, full-range drivers. It also features the award-winning Bluetooth solution, which lets you stream your favorite tunes wirelessly and seamlessly from any compatible Bluetooth device such as a desktop PC, notebook or mobile phone. Also, indulge in fuller and richer music playback with the built-in BassFlex technology that extends the lower frequencies to enhance bass without the need for a subwoofer.
Compatible with any stereo Bluetooth device
Play music on the Creative T12 Wireless wirelessly from any compatible stereo Bluetooth device such as mobile phone, notebook, iPhone, anywhere within 10 meters
Award-winning Bluetooth technology
The same Bluetooth expertise that won our Inspire S2 Wireless 2.0 PC speakers the Bluetooth Special Interest Group "Best of CES 2010" award is also incorporated in the Creative T12 Wireless to bring you the best wireless audio technology has to offer.
High-performance wireless audio
The aptX™ audio codec provides you with superior Bluetooth stereo audio.
Get all the bass in less space
Built-in BassFlex™ technology extends low frequencies to deliver powerful music with more weight - without the need for a bulky subwoofer.
Convenient access to controls
Connect easily to any compatible stereo Bluetooth device at a touch of a button. Also, a headphone jack and volume control located on the front of the speakers let you listen to music on your own terms.
Versatile connectivity options
To enjoy more music stored elsewhere, you can also physically connect other non-Bluetooth devices via a line-in port on the Creative T12 Wireless
Compatible with any Bluetooth-enabled device
Play music on the Creative T12 Wireless wirelessly from any Bluetooth-enabled device such as mobile phone, notebook, iPhone or iPad, anywhere within 10 meters. -
The same Bluetooth expertise that won the Inspire S2 Wireless 2.1 speakers the Bluetooth special interest group "Best of CES 2010" award is also incorporated in the Creative T12 Wireless to bring you the best wireless audio technology has to offer. -
High performance wireless audio
The apt-X audio codec provides you with superior Bluetooth stereo audio. -
Built-in BassFlex technology extends low frequencies to deliver powerful music with more weight - without the need for a bulky subwoofer. -
Connect easily to any Bluetooth device at a touch of a button. Also, a headphone jack and volume control located on the front of the speakers let you listen to music on your own terms.
- Creative Inspire T12 Wireless - speakers - for PC - wireless
- Product Type
- Speakers - for PC
- System Components
- 2 speakers
- Speaker Type
- Active
- Frequency Response
- 20 - 20000 Hz
- Amplifier
- Integrated
- Bluetooth
- Speaker System Details
- 2 20 - 20000 Hz
- 7.1 cm x 9.8 cm x 18 cm
- 1.16 kg
- Product Type
- Speakers - for PC
Speaker System
- System Components
- 2 speakers
- Speaker Type
- Active
- 20 - 20000 Hz
- Signal-To-Noise Ratio
- 80 dB
- Amplifier
- Integrated
- Bluetooth 2.1 EDR
- Bluetooth Profiles
- Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Transmission Range
- 10 m
- Controls
- Power on/off, volume
- Speakers Included
- 2 - 20 - 20000 Hz - wireless
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm) , Headphones (mini-phone stereo 3.5 mm)
- Included Accessories
- Power adapter
- Power Device
- Power adapter - external
- Power Source
- AC power adapter
- 7.1 cm
- 9.8 cm
- 18 cm
- 1.16 kg
