Creative Aurvana Gold Bluetooth Headphones
Quicklinx: C3VKWS00 Mfr#: 51EF0570AA001
Aurvana Gold lets you enjoy fuss-free pairing to your Bluetooth-enabled devices with its Near Field Communication (NFC) feature. With built-in dual microphones, surrounding ambient noise is being electronically cancelled, reducing noise by up to 85%. Featuring superb 40 mm Neodymium drivers, plus high-definition aptX and AAC audio codecs, Aurvana Gold delivers a visceral acoustic performance.
  • Designer sound performance
    Immerse yourself in superb wireless acoustics and noise-free bliss with the Aurvana Gold headset. Featuring superb 40 mm Neodymium drivers, high-definition aptX and AAC audio codecs, the Aurvana Gold delivers a visceral acoustic performance.
  • Exceptional acoustics
    Its 40 mm neodymium drivers have been rigorously tuned to deliver remarkable acoustic performance with tight bass.
  • Excellent design
    Indulge in your marathon entertainment sessions with comfortable, premium memory-foam ear cushions.
  • One-touch connection
    Integrated with Near Field Communication (NFC), you can wirelessly connect to compatible smartphones or tablets easily simply by tapping your smart device on the headset.
  • High-definition playback quality minus the wires
    Aurvana Gold employs high-definition audio support with aptX and AAC to ensure the best wireless audio performance from a Bluetooth-enabled device.
  • Convenient and easy controls
    The convenient on-ear and call controls allow you to adjust the volume or switch between calls and music with ease.
  • Have it both ways
    Enjoy your music with or without wires with the detachable, flat, tangle-free cables.
  • Superb noise eliminator
    With dual embedded microphones, Aurvana Gold offers up to 85% Active Noise Cancellation (ANC).
  • Crisp conversations
    The built-in speech microphone with ClearSpeech Engine actively suppresses environmental noise and digitally enhances voice clarity so that your conversations are loud and clear.
  • One source, two headsets
    Aurvana Gold features Creative ShareMe, which allows you to share your music wirelessly with your buddy or loved one using another Creative ShareMe-enabled wireless headset.
  • Two sources, one headset
    Creative Multipoint allows you to pair two separate devices to the headset at the same time. This means that you can easily switch your music source between these two Bluetooth stereo devices.
Creative Aurvana Gold - headphones with mic
Headphones - Bluetooth - wireless, wired - NFC
Recommended Use
Portable electronics
Black, gold
Headphones Form Factor
Full size binaural
Wireless, wired
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 3.0
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 15 - 22000 Hz - Sensitivity 105 dB/mW
Impedance
32 Ohm
Active Noise Canceling
Controls
Volume, answer/end
292 g
Black, gold
Recommended Use
Audio Output
Full size binaural
Wireless, wired
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 3.0
Sound Output Mode
Stereo
Frequency Response
15 - 22000 Hz
Sensitivity
105 dB/mW
Impedance
32 Ohm
Diaphragm
40 mm
Magnet Material
Neodymium
Remote Control
Controls
Volume, answer/end
Connector Type
Headphones (sub-mini phone 2.5 mm)
Carrying pouch
Cable Details
Headphones cable - 1.2 m , USB charge cable - 1 m , Airplane connection adapter
Rechargeable - Lithium Ion
620 mAh
