Creative Airwave HD - Black
Quicklinx: 8T97WS00 Mfr#: 51MF8165AA000
Portable Wireless Speaker with NFC
Simplify your life with the clever features of the Creative Airwave HD. Enjoy easy one-touch pairing to your smart devices via Near Field Communications (NFC), or with conventional Bluetooth® pairing. With its rechargeable Li-ion battery, this compact yet powerful speaker lets you take your music everywhere with you!
Tap and play!
The Creative Airwave HD features NFC technology which allows for easy, one-touch pairing by simply tapping your NFC-enabled Bluetooth smart device on the speaker.
Pair and stream
As for your smart devices that are not NFC-enabled, you can easily pair them with the Creative Airwave HD via Bluetooth using the conventional method.
The speaker also features Creative Multipoint, which allows you to connect two Bluetooth stereo devices to it.
Integrated Aux-In
If wireless is not your cup of tea, there is always an option to connect your device directly to the speaker via the integrated analog Aux-in connector.
7 hours of non-stop music
Party all night long on a single charge! The Creative Airwave HD gives you up to 7 hours3 of playtime, so don't stop the music!
Built-in Li-ion battery
With a built-in Li-ion battery, your Creative Airwave HD is truly portable and you're free to place your speaker almost anywhere you please. You can check your battery levels with voice prompts and the speaker LED also alerts you when you're low on battery. In addition, the battery level icon is displayed when paired with selected smartphones. The battery can be easily charged via a standard micro USB connection or using the included power adapter.
Small size, huge sound
The Creative Airwave HD houses a Super Charged Amplifier which works in tandem with two premium full-range drivers. These enable the speaker to produce sound louder than speakers twice its size!
Clear voice calls
Turn your speaker into a speaker phone with the built-in concealed microphone for dialog clarity in your voice communications.
Make a statement
The Creative Airwave HD's unique design is a radical departure from the usual rectangular-shaped speakers. The chassis is constructed to minimize vibrations and the optimal 30-degree front baffle tilt projects audio directly to the listener. Available in black or red, its unconventional triangular-styled construction, geometric face panel design and smooth curves make it a refreshing addition to any setting.
  • Tap and play
  • Pair and stream
    As for your smart devices that are not NFC-enabled, you can easily pair them with the Creative Airwave HD via Bluetooth using the conventional method. The speaker also features Creative Multipoint, which allows you to connect two Bluetooth stereo devices to it.
  • Integrated aux-in
  • Built-in Li-ion battery
  • Small size, huge sound
    The Creative Airwave HD houses a super charged amplifier which works in tandem with two premium full-range drivers. These enable the speaker to produce sound louder than speakers twice its size!
  • Clear voice calls
  • Make a statement
Creative Airwave HD - speaker - for portable use - wireless
Speaker - for portable use
Speaker Type
Active
Amplifier
Integrated
Bluetooth, NFC
Speaker System Details
1 x portable speaker
Speaker Details
Speaker - stereo x 2 - active
Grey
Built-in Decoders
SBC decoder, aptX
Power Options
USB charging
Speaker battery rechargeable - Lithium Ion
26 cm x 9.5 cm x 9.5 cm
980 g
Enclosure Colour
Grey
Speaker System
Speaker Type
Active
Amplifier
Integrated
Bluetooth 3.0, Near Field Communication (NFC)
Bluetooth Profiles
Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Transmission Range
10 m
Built-in Decoders
SBC decoder, aptX
Speakers Included
1 x portable speaker - wireless
Speaker Details
Connector Type
Audio line-in (mini-phone stereo 3.5 mm)
USB power adapter
Power Source
Options
USB charging
Rechargeable - Lithium Ion
Run Time (Up To)
7 hour(s)
26 cm
9.5 cm
9.5 cm
980 g
