Sleek and compact, the Creative A60 speakers deliver good and reliable audio, be it for your MP3 player, notebook or PC. Ideal for office or home use, these sleek and compact speakers are especially designed to take up minimal space. Furthermore, this magnetically-shielded speaker system with two 2.75" quality drivers prevents interference with your TV/monitor, while providing you with quality audio for all your entertainment needs. The built-in bass port also helps to enhance the bass and give your audio that extra boost!
- Creative A60 - speakers - for PC
- Product Type
- Speakers - for PC
- System Components
- 2 speakers
- Enclosure Design
- Bass reflex
- Speaker Type
- Active
- Nominal Output Power (Total)
- 4 Watt
- Frequency Response
- 90 - 20000 Hz
- Amplifier
- Integrated
- Speaker System Details
- 2 2 Watt - 90 - 20000 Hz
- 8.5 cm x 8.5 cm x 17.6 cm
- Product Type
- Speakers - for PC
- Enclosure Design
- Bass reflex
Speaker System
- System Components
- 2 speakers
- Speaker Type
- Active
- Audio System Continuous Power (Total)
- 4 Watt
- 90 - 20000 Hz
- Signal-To-Noise Ratio
- 75 dB
- Magnetic Shield
- Amplifier
- Integrated
- Speakers Included
- 2 - 2 Watt - 90 - 20000 Hz - wired
- Driver Details
- Full-range driver - 2.75"
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm)
- Power Source
- AC power adapter
- 8.5 cm
- 8.5 cm
- 17.6 cm
