Creative A250 2.1 PC Speaker System
Quicklinx: 8NMLWS00 Mfr#: 51MF0420AA004
£21.58 ex VAT
£25.89 inc VAT
ENJOY IMPRESSIVE 2.1 SOUND WITH SOLID BASS
The A250 lets you experience your movie, game or music louder then ever before with innovations that create a full spectrum, louder and more detailed audio with an enhanced mid-bass and amazingly accurate sonic imaging. All these with the newly designed Creative DSE (Dual Slot Enclosure) and Creative IFP (Image Focusing Plate).
Big sound from a compact system
The speaker system's satellites feature the Creative DSE design, which enables them to achieve louder and deeper playback even when constrained to a compact housing. This is made possible by separating the port tube into two separate slots and reconstructing them to fit into a tight enclosure. Their space-saving size allows for easy and versatile placement anywhere in the home.
Enjoy natural sounding audio
The newly-improved Creative IFP design features an extended flare surrounding the satellite driver to provide an even wider acoustic sweet spot. This improves sonic directivity to the listening area, giving music more focus while preserving tonal accuracy
Largest-in-class, down-firing subwoofer
The system's largest-in-class, down-firing ported subwoofer delivers impressive bass for that extra oomph in your music.
Convenient controls
The ON/OFF switch integrated with volume control is conveniently located on the satellite for easy access.
  • Enjoy natural sounding audio
  • Largest-in-class, down-firing subwoofer
  • Convenient controls
    The on/off switch integrated with volume control is conveniently located on the satellite for easy access.
Creative A250 - speaker system - for PC
Speaker system - for PC - 2.1-channel
System Components
2 speakers, subwoofer
Speaker Type
Active
Nominal Output Power (Total)
9 Watt
Frequency Response
40 - 20000 Hz
Amplifier
Integrated
Speaker System Details
2 x satellite speaker 2 Watt , 1 x subwoofer 5 Watt
Speaker System
System Components
Speaker Type
Active
Audio System Continuous Power (Total)
9 Watt
Frequency Response
40 - 20000 Hz
Signal-To-Noise Ratio
75 dB
Amplifier
Integrated
Speakers Included
2 x satellite speaker - 2 Watt - wired , 1 x subwoofer - 5 Watt - wired
Power Source
AC power adapter
Dimensions (WxDxH) / Weight Details
Left channel speaker: 7.2 cm x 7.9 cm x 14.7 cm / 258 g , Right channel speaker: 7.2 cm x 7.9 cm x 14.7 cm / 361 g , Subwoofer: 18.3 cm x 19 cm x 22.5 cm / 1.56 kg
System Type: PC multimedia home theatre speaker system
Type: 2 speakers
Power: 9watt
Brand: Creative
