The Corsair VS650 is a great choice if you’re building a home or office system with lower power demands, but you still demand the compatibility and reliability that Corsair is known for.
Real power
The VS650 delivers a guaranteed 650 Watts of continuous power. With 0.99 Active Power Factor correction, you get the peace of mind from knowing that your components are protected from uneven power delivery. And a dedicated single +12V rail saves you from the hassle of balancing your components across multiple power cables. -
Low noise, high efficiency
The 120mm fan is thermally controlled, so it only spins at maximum speed when it's pushed hard - and even at full load, it's pretty quiet. Smart design features like this are why VS650 offers up to 85% efficiency. Your PC system will generate less heat, and you'll enjoy lower energy bills. -
Sophisticated design
The black powder-coated enclosure and the black-sleeved cables give any system a polished look. You're building a PC, not a battleship, and with the VS650 you can avoid that look of unpainted steel that you'll find on so many entry-level power supplies.
- CORSAIR VS Series VS650 - power supply - 650 Watt
- Power supply - active Power Factor Correction (PFC) - internal
- Specification Compliance
- ATX12V 2.3/ EPS12V
- 80 PLUS Certification
- 80 PLUS
- 1.5 kg
- Localisation
- United Kingdom
- Input Voltage
- AC 200-240 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 650 Watt
- Output Current
- +3.3V - 20 A , +5V - 20 A , +12V - 50 A , -12V - 0.3 A , +5VSB - 2.5 A
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V , 4 x 15 pin Serial ATA power , 4 x 4 PIN internal power , 2 x 4 PIN mini-power connector
- Cooling System
- 120 mm fan
- Included Accessories
- Cable ties, mounting kit
- Black powder coat
- 15 cm x 14 cm x 8.6 cm
- 3-year warranty
- PSU Form Factor
- ATX
- Black powder coat
- Localisation
- United Kingdom
- Input Voltage
- AC 200-240 V
- Frequency Required
- 47 - 63 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 650 Watt
- Output Current
- Efficiency
- 85%
- 80 PLUS
- MTBF
- 100,000 hours
- Cooling System
- 120 mm fan
- Sleeved cables, over current protection, over voltage protection, undervoltage protection, short-circuit protection, single 12V rail, temperature controlled fan, non-modular
- FCC Class B certified, TUV, C-Tick, CB, CCC, cTUVus
- Limited warranty - 3 years
- 15 cm
- 14 cm
- 8.6 cm
- 1.5 kg
- Shipping Width
- 26 cm
- Shipping Depth
- 18 cm
- Shipping Height
- 9.6 cm
- Shipping Weight
- 1.64 kg
