Imagine no more emailing photos to yourself, hunting for a USB cable, or running out of room on your USB OTG compatible Android phone or tablet. Flash Voyager GO is the quick and easy way to move photos, music and videos between your mobile devices and your PCs and dramatically increase your devices' storage. The ingenious design has both a USB and a Micro-USB connector, so you can copy photos and videos to your desktop or notebook PC for safekeeping, share music and media between your PCs and your Android device, or just leave it connected to the Micro-USB port for a huge boost to your device's storage capacity.
Flash Voyager GO has both a USB 3.0 connector for your PC or Mac, and a Micro-USB connector for your Android phone or tablet. It requires a newer Android device with USB On-The-Go (also known as USB OTG) support.
The easy way to move photos, music and videos between your Android phone or tablet and your PC
Imagine no more emailing photos to yourself, hunting for a USB cable, or running out of room on your USB OTG compatible Android phone or tablet. Flash Voyager GO is the quick and easy way to move photos, music and videos between your mobile devices and your PCs and dramatically increase your devices' storage. The ingenious design has both a USB and a Micro-USB connector, so you can copy photos and videos to your desktop or notebook PC for safekeeping, share music and media between your PCs and your Android device, or just leave it connected to the Micro-USB port for a huge boost to your device's storage capacity. -
Designed for Android devices with USB On-The-Go support
Flash Voyager GO has both a USB 3.0 connector for your PC or Mac, and a Micro-USB connector for your Android phone or tablet. It requires a newer Android device with USB On-The-Go (also known as USB OTG) support. -
The solution to your photo and video problem
Have you ever snapped a photo, and then emailed it to yourself so you'd have a copy on your PC? Have you ever backed up your photos and videos to a low-resolution site like Facebook or Instagram, and then deleted them to save room? Or, do you simply like taking photos and videos more than you like to manage your photo collection? Flash Voyager GO is here to help. Any time you want to share some mediaor clear room on your Android phone or tablet, just attach the Flash Voyager GO, select and copy the images and videos you'd like to save, and then copy them to your desktop or notebook PC at your leisure. You don't need to be at your PC or hunt for a USB cable. And unlike cloud storage, Flash Voyager GO lets you keep control of your media... and there's never a monthly fee! -
Dramatically increase your device's storage
That might seem like a lot at first, but once you add apps, odds are that it just doesn't have enough room for all the music, photos and videos in your collection. And, upgrading your device's memory card - or worse yet, replacing it with a higher-capacity model - can be an expensive proposition. With Flash Voyager GO, just attach it to your PC, copy your collection, and then snap it in to the Micro-USB port on your mobile device any time you want.
- CORSAIR Flash Voyager GO - USB flash drive - 64 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.0
- Storage Capacity
- 64 GB
- Localisation
- European Union
- OS Required
- Linux, Apple MacOS X, Microsoft Windows, Android
- 5-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 64 GB
- Localisation
- European Union
- Interface Type
- USB 3.0
- USB On-The-Go compatible, micro-USB connector
- Included Accessories
- Lanyard, 1 extra cap
- Plug and Play
- OS Required
- Limited warranty - 5 years
- 3.7 mm
- Thickness
- 1.2 mm
- 0 °C
- 50 °C
