Corsair Vengeance 32GB (2 x 16Gb) DDR4 B Illuminated Memory Kit - Blue LED Lighting
Quicklinx: D92CWS00 Mfr#: CMU32GX4M2C3200C16B
Vengeance Low Profile heat spreaders have a reduced height of 1.03". They're designed for high-performance systems with extra-large CPU coolers, small form factor system builds, or any other space-constrained application where you need high-performance memory but standard Vengeance modules might not fit.
  • Great looking, great overclocking memory
    Corsair Vengeance memory modules are designed with overclockers in mind. Vengeance DIMMs are built using RAM specially selected for their high-performance potential. Aluminum heat spreaders help dissipate heat, and provide the aggressive look that you want in your gaming rig.
  • Optimized for compatibility with the CPUs and motherboards
    Vengeance memory is designed specifically for the latest CPUs. The 1.5V VDIMM spec ensures you get the performance you expect, even without increasing memory voltages.
CORSAIR Vengeance LED - DDR4 - kit - 32 GB: 2 x 16 GB - DIMM 288-pin - 3200 MHz / PC4-25600 - unbuffered
Memory kit
32 GB: 2 x 16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
3200 MHz (PC4-25600)
Latency Timings
CL16 (16-18-18-36)
Dual channel, Vengeance heatspreader, anodized aluminum heatspreader, Intel Extreme Memory Profiles (XMP 2.0), blue activity LED's, 10 Layers PCB heatspreader, unbuffered
Voltage
1.35 V
32 GB: 2 x 16 GB
Upgrade Type
Generic
DRAM memory kit
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL16 (16-18-18-36)
Non-ECC
Voltage
1.35 V
RAM Performance
SPD - 2133 MHz - 1.2 V - CL15 - 15-15-15-36 , Tested - 3200 MHz - 1.35 V - CL16 - 16-18-18-36
Colour Category
