Gold-certified efficiency and semi-modular cabling for low energy use and easy installation
TX Series semi-modular power supplies are ideal for basic desktop systems where low energy use, low noise, and simple installation are essential. All of the capacitors are 105°C rated, Japanese brand, to ensure solid power delivery and long term reliability. 80 PLUS Gold efficiency reduces operating cost and excess heat. Flat, sleeved black modular cables with clearly-marked connectors make installation fast and straightforward, with good-looking results.
80 PLUS Gold-certified Efficiency
The super-efficient operation of the TX Series semi-modular results in lower energy use and lower operating costs. Since it generates less heat, the fan doesn’t need to work as hard, and you’ll enjoy near silent operation.
Modular cabling with clearly marked connectors
The flat, sleeved black cables are semi-modular, so you’ll only use the cables you need and you’ll get great-looking results. The clearly-marked connectors make installation fast and straightforward.
Corsair Engineering and Quality Control
Every CORSAIR power supply is designed by our California engineering team and built to our exact specifications. The same care that goes into the design and testing of our renowned high-power enthusiast power supplies also goes into the TX-M Series semi-modular, because you need confidence and reliability regardless of your build budget.
80 PLUS Gold-certified efficiency
The super-efficient operation of the TX series semi-modular results in lower energy use and lower operating costs. Since it generates less heat, the fan doesn't need to work as hard, and you'll enjoy near silent operation. -
The flat, sleeved black cables are semi-modular, so you'll only use the cables you need and you'll get great-looking results. The clearly-marked connectors make installation fast and straightforward.
- CORSAIR TX-M Series TX750M - power supply - 750 Watt
- Power supply - active Power Factor Correction (PFC) - internal
- Specification Compliance
- ATX12V 2.4/ EPS12V 2.92
- 80 PLUS Certification
- 80 PLUS Gold
- 1.7 kg
- Localisation
- United Kingdom
- Input Voltage
- AC 100-240 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 750 Watt
- Output Current
- +3.3V - 25 A , +5V - 25 A , +12V - 62 A , -12V - 0.8 A , +5VSB - 3 A
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 8 x 15 pin Serial ATA power , 7 x 4 PIN internal power , 4 x 8 pin PCI Express power with detachable 2 pin section
- Modular Cable Management
- Cooling System
- 120 mm fan
- Included Accessories
- Cable tie, screws, 2 x 100mm floppy adapters, case badge
- 15 cm x 14 cm x 8.6 cm
- 7 years warranty
- PSU Form Factor
- ATX
- Localisation
- United Kingdom
- Input Voltage
- AC 100-240 V
- Frequency Required
- 47 - 63 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 750 Watt
- Output Current
- Efficiency
- 90%
- 80 PLUS Gold
- MTBF
- 100,000 hours
- Cooling System
- 120 mm fan
- Sleeved cables, over voltage protection, overpower protection, undervoltage protection, short-circuit protection, thermal protection, rifle bearing cooling fan, semi-modular
- UL, TUV, BSMI, cUL, CB, CCC, FCC, RoHS, WEEE, ICES, KC, EAC, RCM
- Limited warranty - 7 years
- 15 cm
- 14 cm
- 8.6 cm
- 1.7 kg
- Shipping Width
- 21 cm
- Shipping Depth
- 29 cm
- Shipping Height
- 12.9 cm
- Shipping Weight
- 2.65 kg
