Corsair ST100 RGB Premium Headset Stand
Quicklinx: D8Y4WS00 Mfr#: CA-9011167-EU
Proudly display your headset with the ST100 RGB Premium Headset Stand, featuring premium aluminum construction and customizable RGB lighting. Built-in 3.5mm analog input enables full range stereo or 7.1 surround sound for an immersive, multi-channel audio experience. Easy access, dual USB 3.1 inputs provide improved charging power and faster data speeds for your headset, phone, and other devices while the non-slip, rubberized base provides stability and protection for your desk.
CORSAIR Gaming ST100 RGB Premium Headset Stand - sound card - USB 3.1 Gen 1
Sound card
Enclosure Type
External
Interface Type
USB 3.1 Gen 1
12 cm x 12 cm x 25 cm
700 g
Europe
Sound Output Mode
Stereo
DAC Resolution
16-bit
Sample Rate
48 kHz (max)
Sound card
External
Interface Type
USB 3.1 Gen 1
12 cm
12 cm
25 cm
700 g
Europe
Audio Output
Sound Output Mode
Stereo
DAC Resolution
16-bit
Sample Rate
48 kHz (max)
USB bus-powered, virtual 7.1 channel surround mode, 2-port USB hub, RGB lighting, non-slip rubberised base
1 x audio - mini-phone 3.5 mm 4-pole , 2 x USB 3.1 Gen 1 - 9 pin USB Type A , 1 x USB 3.1 Gen 1 - Micro-USB Type B
1 x micro-USB cable - 1.8 m
