Corsair Air Series LED high airflow PC case fans combine efficient, low-noise airflow with striking LED lighting. The custom-molded blades are designed for high-volume air delivery with less noise and turbulence than typical case fans. They're translucent, with a frosted texture, so the light from the four LEDs adds a dramatic effect.
Air Series AF fan models perform best in unrestricted spaces with at least 3 cm of clearance, and they're ideal for mounting at the rear or top of your PC case as exhaust fans for your PC's motherboard and CPU, graphics accelerators, and other components that fill the case with heat. They work equally well as unrestricted intake fans for areas like side panels or bottom intakes.
High static pressure cooling with led illumination
Air Series LED high static pressure PC case fans combine efficient high pressure airflow with striking LED lighting. They're custom designed to deliver air directly to high-temperature components with less noise and turbulence than ordinary fans. -
Designed for restricted spaces
Air Series fan models are designed for use in restricted spaces. They're ideal for radiator and heatsink use, as well as drive bay intakes and other locations where you're mounting a fan directly adjacent to a heat source.
- CORSAIR Air Series LED SP120 RGB High Performance - case fan
- Product Type
- Case fan
- Packaged Quantity
- 3 (specifications are for single item)
- Package Content
- Mounting screws for case fans, 6-port RGB LED hub, fan RGB LED controller
- White, blue, yellow, red, green, orange, violet
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Hydraulic bearing
- Rotation Speed
- 1400 rpm
- Air Flow
- 52 cfm
- Noise Level
- 26 dBA
- Power Connector
- 3-pin plug
- Custom-molded fan blades, RGB LED x4
- 2-year warranty
- Packaged Quantity
- Product Type
- Case fan
- Package Content
Heatsink & Fan
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Hydraulic bearing
- Rotation Speed
- 1400 rpm
- Air Flow
- 52 cfm
- Air Pressure
- 1.45 mm
- Noise Level
- 26 dBA
- Power Connector
- 3-pin plug
- Operation Voltage
- 7 - 13.2 V
- Mounting Kit
- Included
- Limited warranty: - 2 years
