Adjustable backlighting, six G-keys and anti-ghosting for faster, better gaming
The Corsair Raptor K30 gaming keyboard provides the gaming essentials: adjustable backlighting, programmable G-keys with onboard storage and anti-ghosting circuitry for accurate input during fast play.
The red backlighting makes it easy to find critical keys in dimly lit environments. You can select from low-impact, normal, or extra bright lighting, or turn it off entirely. The six dedicated, programmable G-keys allow for easy access to up to 18 of your most-used combinations, and settings are stored onboard, so you can take your K30 from system to system. And, easy-access multimedia controls let you play, stop, pause, skip tracks, and adjust volume directly from the keyboard.
Red backlighting with three illumination settings
It's easy to find critical keys in dimly lit rooms. Select from low-impact, normal, or extra-bright lighting, or turn it off entirely.
Six dedicated, programmable G-keys for storage of up to 18 presets
Access your favorite macros, presets and key combinations, even during the most intense action. Three "M" keys triple the storage capacity.
Game-optimized anti-ghosting circuitry
Every keystroke translates into accurate gameplay--even when multiple keys are pressed.
On-board profile storage
Stores settings and profiles in the keyboard memory so they work independently of software and on other PCs.
Easy-access multimedia controls
Play, stop, pause, skip tracks, and adjust volume directly from the keyboard.
About Corsair Gaming Keyboards
Corsair gaming keyboards are designed for competitive play. Crafted with high-quality components and materials, they offer great key feel and the responsiveness you need when victory is essential. They deliver incredible responsiveness, customizability and precision to elevate your game.
Backlighting with three illumination settings
It's easy to find critical keys in dimly lit rooms. Select from low-impact, normal, or extra-bright lighting, or turn it off entirely. -
Access your favorite macros, presets and key combinations, even during the most intense action. Three "M" keys triple the storage capacity. -
Every keystroke translates into accurate gameplay - even when multiple keys are pressed. -
- CORSAIR Raptor K30 Gaming - keyboard - UK
- Keyboard
- Backlit
- Red
- Interface
- USB
- Connectivity Technology
- Wired
- Localization and Layout
- UK
- Hot Keys Function
- Volume, mute, play/pause, stop, previous track, next track
- 36 KB onboard memory, Windows Lock key, 1000Hz/1ms polling rate, 6 macro hotkeys
- 46.7 cm x 18 cm x 3.5 cm
- 1.05 kg
- 2-year warranty
- Keyboard
- Backlit
- Red
- Interface
- USB
Input Device
- Hot Keys Function
- UK
- Keyboard Technology
- Rubber dome
- Anti-ghosting
- 46.7 cm
- 18 cm
- 3.5 cm
- 1.05 kg
- Cables Included
- 1 x USB cable
- OS Required
- Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Windows 8
- Limited warranty - 2 years
