Corsair ML120 Pro ML Series 120mm Magnetic RPM Fan
Quicklinx: C7H0WS00 Mfr#: CO-9050040-WW
Corsair is expanding its range of fans with the introduction of the ML series, an acronym that reveals the technological nature of the new series of magnetic levitation fans.
The Corsair ML fans provide quiet operation and excellent performance, thanks to magnetic levitation of the rotor and the owner of the design of the fan blades.
The innovative design is able to considerably increase both the static pressure and a flow of air, thanks to the very low friction of the magnetic levitation system.
Moreover, thanks to the 4-pin PWM connector is possible to adjust timely the fan rotation speed so as to manage the performance / noise ratio appropriately.
The PRO version includes in the package a set of silicone nose pads, interchangeable with optional sets of various colors (red, white and blue) that have the dual function to cancel the vibrations produced by the fan itself and beautify the fan, matching the color of nose pads to that of your system!
Finally, the LED version is equipped with 4 high-brightness LED inserted in the rotor of the fan, guaranteeing maximum brightness and uniform lighting along the translucent material blades.
  • Magnetic bearing
    Harnesses magnetic levitation technology to provide lower noise, higher performance, and a longer lifespan.
  • Custom rotor design
    Delivers the perfect balance between high static pressure and high airflow, operating flawlessly in the challenging environments.
  • Extensive control range
    A high control range gives you total control between low noise and absolute performance.
CORSAIR ML Series ML120 PRO Premium Magnetic Levitation - case fan
Case fan
Package Content
Mounting screws for case fans
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Magnetic bearing
Rotation Speed
400-2400 rpm
Air Flow
12-75 cfm
Noise Level
16 - 37 dBA
Power Connector
4-pin fan connector
Pulse-width modulation (PWM) support
5-year warranty
Case fan
Package Content
Heatsink & Fan
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Magnetic bearing
Rotation Speed
400-2400 rpm
Air Flow
12-75 cfm
Air Pressure
0.2-4.2 mm
Noise Level
16 - 37 dBA
Power Connector
4-pin fan connector
Rated Current
0.225 A
Limited warranty: - 5 years
