The K55 combo is your first step toward victory. Together, this duo comes packed with the essential features to step up your game.
Programmable macro keys
Assign single keystrokes or complex multi-key combos to any of the dedicated macro keys, without any additional software required to be installed. -
Dedicated volume and multimedia controls
Adjust your audio without interrupting your game with direct access to volume and media playback. -
Quiet and responsive keys
Minimum noise and satisfying feel without sacrificing performance. -
Lightweight design
Designed to fit naturally in your hand and support multiple grip styles.
- CORSAIR Gaming K55 + HARPOON RGB Combo - keyboard and mouse set - UK Input Device
- Keyboard and mouse set
- Backlit
- RGB
- Interface
- USB
- Connectivity Technology
- Wired
- Localization and Layout
- UK
- Hot Keys Qty
- 6
- Hot Keys Function
- Mute, play/pause, stop, previous track, next track, volume -, volume +, Windows key lock
- Numeric Keypad
- Pointing Device
- Mouse - wired - optical - left-handed
- Buttons Qty
- 6
- Gaming
- 2-year warranty
- Backlit
- RGB
- Interface
- USB
- Dimensions (WxDxH) / Weight
- Keyboard: 48.02 cm x 16.63 cm x 3.46 cm / 907 g
- Hot Keys Qty
- 6
- Hot Keys Function
- UK
- Simultaneous Key Press Quantity
- 8
- Gaming
- Palm Rest
- Numeric keypad
Pointing Device
- Mouse - wired
- Buttons Qty
- 6
- Movement Detection Technology
- Optical
- Movement Resolution
- 6000 dpi
- Orientation
- Left-handed
- Backlit
- RGB
- Included Accessories
- Soft rubber wrist rest
- OS Required
- Microsoft Windows Vista / 7 / 8 / 10
- Limited warranty - 2 years
