Corsair Hydro Series H80i GT High Performance Liquid CPU Cooler
Quicklinx: B3LSWS00 Mfr#: CW-9060017-WW
The Hydro Series H80i GT is a high performance, all-in-one liquid CPU cooler that works with standard 120mm radiator mounts. The extra-thick 49mm x 120mm radiator and dual SP120L PWM fans provide the excellent heat dissipation you need for high performance CPUs. It's Corsair Link compatible, so you can customize cooling performance, monitor system temperature, and change the color of the RGB LED lighting.
Corsair Hydro Series CPU coolers give you the power of liquid cooling in a compact, easy-to-install package. They offer superior cooling for higher overclocking performance, without the complexity of traditional water cooling kits.
  • Extra-thick radiator
    The 120mm radiator works with standard 120mm fan mounts for wide compatibility, but has a depth of 49mm for increased cooling surface area and faster, more efficient cooling.
  • Customized cooling performance
    You can select the speed of the dual SP120L PWM fans via the Corsair Link control panel or any standard fan speed utility. And, you have options: use just one fan to save space, or install both in a push-pull configuration for extra cooling efficiency.
  • Built-in Corsair Link
    Attach the included Corsair Link cable to a USB header on your motherboard and download the free Corsair Link software to unlock even more power. You can customize cooling performance, monitor coolant and CPU temperatures, and change the color of the RGB LED lighting from the default white to match your system or to change color based on temperature readings and other inputs.
  • High-performance CPU cooling made simple
    The H80i GT is a closed loop design that comes pre-filled. It includes a modular, tool-free mounting bracket for faster installation, and it features improved coldplate and pump designs for highly tuned efficiency.
CORSAIR Hydro Series H80i GT High Performance Liquid CPU Cooler - processor liquid cooling system
Processor liquid cooling system
Compatibility
LGA1156 Socket, Socket AM2, LGA1366 Socket, Socket AM3, LGA1155 Socket, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket, LGA2011-3 Socket, LGA1200 Socket
Heatsink Material
Copper
Fans Qty
Dual
Fan Diameter
120 mm
Fan Height
25 mm
Rotation Speed
2435 rpm
Air Flow
70.7 cfm
Noise Level
37.7 dBA
Pulse-width modulation (PWM) support
1.8 kg
Corsair Link
5-year warranty
1.8 kg
Heatsink & Fan
Compatible With
Heatsink Material
Copper
Fans Qty
2
Fan Diameter
120 mm
Fan Height
25 mm
Rotation Speed
2435 rpm
Air Flow
70.7 cfm
Air Pressure
4.65 mm
Noise Level
37.7 dBA
Mounting Kit
Included
Corsair Link
Limited warranty: - 5 years
