The Hydro Series H45 makes your PC run cooler and quieter when you replace your CPU’s stock heatsink. The compact components and flexible tubing make the Hydro Series H45 easy to install even if you’re cramped for space. It allows you to improve your CPU’s cooling efficient even in the most compact cases – as long as your case has a 120mm fan mount near the CPU, the H45 will probably fit. The H45 comes pre-filled, and never needs priming.
 - CORSAIR Hydro Series H45 Performance Liquid CPU Cooler - processor liquid cooling system
- Product Type
 - Processor liquid cooling system
- Package Content
 - Mounting screws, thermal compound
- Compatibility
 - LGA1156 Socket, Socket AM2, Socket AM3, LGA1155 Socket, LGA2011 Socket, LGA1150 Socket, LGA1151 Socket, Socket AM4, LGA2066 Socket
- Fan Diameter
 - 120 mm
- Rotation Speed
 - 2300 rpm
- Air Flow
 - 94 cfm
- Noise Level
 - 31 dBA
 - Pulse-width modulation (PWM) support
- Product Material
 - Aluminium, copper
 - 16.85 cm x 12 cm x 7.1 cm
 - 796 g
 - 5-year warranty
- Product Type
- Product Material
 - Aluminium, copper
- Package Content
 - 16.85 cm
 - 12 cm
 - 7.1 cm
 - 796 g
Heatsink & Fan
- Compatible With
- Fan Diameter
 - 120 mm
- Rotation Speed
 - 2300 rpm
- Air Flow
 - 94 cfm
- Air Pressure
 - 3.65 mm
- Noise Level
 - 31 dBA
- Mounting Kit
 - Included
 - Limited warranty: - 5 years
