Corsair Hydro Series H115i Extreme Performance Liquid CPU Cooler
Quicklinx: BYQMWS00 Mfr#: CW-9060027-WW
Hydro Series H115i is an all-in-one liquid CPU cooler with a 280mmradiator and dual SP140L PWM fans for cooling that’s far superior to stock CPU air coolers. Liquid cooling works better than air cooling, and the self-contained design of the H115i gets you up and running quickly so you can spend more time enjoying the performance of your overclocked processor and less time assembling, filling, and maintaining your cooling system.
The H115i has Corsair Link software control built in. Just attach the included cable to a USB header on your motherboard and download the software from Corsair.com, then customize and monitor your temps, fan and pump speeds, and even the RGB LED logo on the coldplate.
  • Large 280mm radiator: More cooling capacity for cases which have 280mm radiator mounts.
  • Improved coldplate and pump design: Better efficiency gives you lower temperatures with less noise.
  • Advanced SP140L PWM fan design: Better high-static pressure air delivery and customizable speed.
  • Built-in Corsair Link: Monitor CPU and coolant temperature, adjust fan speed, and customize lighting directly from your desktop.
Includes:
  • Corsair Hydro Series H115i Extreme Performance Liquid CPU Cooler
  • Mounting kit for all modern CPU sockets
  • Two SP140L High Torque 140mm fans
  • USB cable for Corsair Link. Integration
  • Fan and radiator mounting screws
  • Thermal compound (pre-applied)
  • 280 mm dual-fan radiator
    The key to fast, efficient cooling is maximizing cooling surface area. If your PC case has dual 140 mm fan mounts spaced for a 280 mm radiator, the H115i lets you take advantage of your case's full cooling potential.
  • High-performance CPU cooling made simple
    Gone are the days when watercooling required lots of work. The H115i is a closed loop design that comes pre-filled, and it comes with a modular, tool-free mounting bracket for faster installation.
  • Hydro Series liquid CPU Coolers
    Corsair Hydro Series CPU coolers give you the power of liquid cooling in a compact, easy-to-install package. They offer superior cooling for higher overclocking performance, without the complexity of water cooling kits.
CORSAIR Hydro Series H115i Extreme Performance Liquid CPU Cooler - processor liquid cooling system
Processor liquid cooling system
Compatibility
LGA1156 Socket, Socket AM2, LGA1366 Socket, Socket AM3, LGA1155 Socket, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket, LGA2011-3 Socket, LGA1151 Socket
Heatsink Material
Aluminium with copper base
Fans Qty
Dual
Fan Diameter
140 mm
Fan Height
25 mm
Rotation Speed
2000 rpm
Air Flow
104.65 cfm
Noise Level
40 dBA
Pulse-width modulation (PWM) support
14 cm x 31.2 cm x 5.1 cm
1.9 kg
Corsair Link
5-year warranty
14 cm
31.2 cm
5.1 cm
1.9 kg
Heatsink & Fan
Compatible With
Heatsink Material
Fans Qty
2
Fan Diameter
140 mm
Fan Height
25 mm
Rotation Speed
2000 rpm
Air Flow
104.65 cfm
Air Pressure
3.99 mm
Noise Level
40 dBA
Mounting Kit
Included
Corsair Link
Limited warranty: - 5 years
