Hydro Series H100i v2 is an all-in-one liquid CPU cooler with a 240mm radiator and dual SP120L PWM fans for cooling that's far superior to stock CPU cooling fans. Liquid cooling simply works better than air cooling, and the self-contained design of the H100i v2 makes it easy for you to protect your valuable CPU.
The H100i v2 has Corsair Link built in. Just attach the included cable to a USB header on your motherboard and download the free Corsair Link software, and you can monitor CPU and coolant temperatures, adjust fan speeds, and customize the LED lighting directly from your desktop.
- 240mm dual-fan radiator: More surface area for superior cooling performance.
- Improved coldplate and pump design: Better efficiency gives you lower temperatures with less noise.
- Advanced SP120L PWM fan design: Better high-static pressure air delivery and customizable speed.
- Built-in Corsair Link: Monitor CPU and coolant temperature, adjust fan speed, and customize lighting directly from your desktop.
- User replaceable inserts: Change the colour of your cooler to match your system with the user-replaceable inserts on the radiator and pump cap (Sold Separately).
Includes:
- Corsair Hydro Series H100i v2 High Performance Liquid CPU Cooler
- Mounting kit for all modern CPU sockets
- Two SP120L High Torque 120mm fans
- USB cable for Corsair Link Integration
- Fan and radiator mounting screws
- Thermal compound (pre-applied)
- Quick Start Guide
Advanced PWM fans
The fans are different than standard case fans - they're designed to deliver high static pressure for mounting directly against radiators, and the fan blades are specially shaped for maximum air delivery with minimum noise. Since they're PWM controlled, you can customize the fan speed to choose the optimal point on the performance/noise curve. -
Built-in Corsair Link for monitoring, customization, and control
Attach the included Corsair Link cable to a USB header on your motherboard and unlock even more power. You can customize cooling performance, monitor coolant and CPU temperatures, and change the color of the RGB LED lighting from the default white to match your system, or to change color based on temperature readings and other inputs. -
High-performance CPU cooling made simple
Gone are the days when water cooling required lots of work. The H100i v2 is a closed loop design that comes pre-filled, and it features a modular, tool-free mounting bracket for faster installation.
- CORSAIR Hydro Series H100i v2 Extreme Performance Liquid CPU Cooler - processor liquid cooling system
- Product Type
- Processor liquid cooling system
- Package Content
- Thermal paste
- Compatibility
- LGA1156 Socket, Socket AM2, LGA1366 Socket, Socket AM3, LGA1155 Socket, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket, LGA2011-3 Socket, LGA1151 Socket
- Heatsink Material
- Aluminium with copper base
- Fans Qty
- Dual
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Rotation Speed
- 2435 rpm
- Air Flow
- 70.7 cfm
- Noise Level
- 37.7 dBA
- Pulse-width modulation (PWM) support
- Corsair Link
- 5-year warranty
- Product Type
- Package Content
- Thermal paste
Heatsink & Fan
- Compatible With
- Heatsink Material
- Fans Qty
- 2
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Rotation Speed
- 2435 rpm
- Air Flow
- 70.7 cfm
- Air Pressure
- 4.65 mm
- Noise Level
- 37.7 dBA
- Mounting Kit
- Included
- Corsair Link
- Limited warranty: - 5 years
