HXi Series power supplies give you extremely tight voltage control, virtually silent operation, and a fully modular cable set. With all Japanese 105°C capacitors, they're a great choice for high performance PCs where reliability is essential. 80 PLUS Platinum efficiency reduces operating cost and excess heat, and together with Zero RPM Fan Mode technology, gives you virtually silent operation.
With Corsair Link Digital support, you can monitor power supply performance, toggle single rail or multi rail mode, and control fan speed directly from your desktop. And, the fully modular, low profile cable set makes builds and upgrades easy, with clean, great-looking results.
Quiet, efficient operation
80 PLUS Platinum efficiency and Zero RPM Fan Mode mean that at low to medium loads, the fan doesn't spin at all. And when you do push the HXi hard, the thermally controlled fan spins only as fast as it needs to. But that's not all. It's quieter than most PSUs when the fan's not spinning, too. The HXi is built with capacitors and other internal components specially selected to reduce coil whine and other electronic noise. -
Corsair link digital for advanced monitoring and control
Connect the included cable to a motherboard USB header and download the free Corsair Link Dashboard application for Windows and you can monitor performance and efficiency, toggle single rail or multi rail mode, and control fan speed directly from your desktop. -
Easy installation
The fully modular, low-profile cable set allows for quick and easy installation and great-looking builds. The fan self-test switch lets you quickly confirm operation before you even attach cables to your motherboard.
- CORSAIR HXi Series HX1200i - power supply - 1200 Watt
- Power supply - internal
- Specification Compliance
- ATX12V 2.4/ EPS12V 2.92
- 80 PLUS Certification
- 80 PLUS Platinum
- 3.592 kg
- Localisation
- United Kingdom
- Input Voltage
- AC 100-240 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 1200 Watt
- Output Current
- +3.3V - 30 A , +5V - 30 A , +12V - 100 A , -12V - 0.8 A , +5VSB - 3.5 A
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 2 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 8 x 8 pin PCI Express power with detachable 2 pin section , 12 x 4 PIN internal power , 12 x 15 pin Serial ATA power , 2 x 4 PIN mini-power connector
- Modular Cable Management
- Cooling System
- 140 mm fan
- 15 cm x 20 cm x 8.6 cm
- 10 years warranty
- PSU Form Factor
- ATX
- Localisation
- United Kingdom
- Input Voltage
- AC 100-240 V
- Frequency Required
- 47 - 63 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 1200 Watt
- Output Current
- Efficiency
- 92%
- 80 PLUS Platinum
- Cables Included
- Power cable kit
- Cooling System
- 140 mm fan
- Corsair Link, fan speed monitoring, over current protection, over voltage protection, undervoltage protection, short-circuit protection, Zero RPM fan mode, fluid dynamic bearing cooling fan, fully modular
- CSA, UL, TUV, C-Tick, cUL, CB, FCC, RoHS, WEEE, ICES, REACH, KC, China RoHS, RCM
- Limited warranty - 10 years
- 50 °C
- 15 cm
- 20 cm
- 8.6 cm
- 3.592 kg
