Corsair HG10 N970 Edition GPU Hydro Cooler Bracket
Quicklinx: BTJMWS00 Mfr#: CB-9060005-WW
Discontinued, only used stock available
The Hydro Series HG10 A1 GPU liquid cooling bracket allows you to adapt a Corsair Hydro Series liquid CPU cooler (not included) to your GPU. It’s compatible with reference design AMD Radeon 290 and 290X graphics cards and it installs quickly and easily.
  • The best upgrade you can make to your GPU
    Liquid cooling is superior to air cooling - it's basic physics. With the HG10 A1, upgrading your GPU to liquid cooling has never been easier. The HG10 A1 protects your investment in your GPU, helps it run cooler, and gives you more overclocking headroom. And with the added bonus of allowing your GPU to run quieter, once you've moved to liquid cooling you'll never want to go back.
  • Run cooler and quieter
    Using a Hydro Series HG10 A1 can reduce your GPU's temperature by up to 50° C. Most GPUs have a temperature-controlled fan, and when your GPU detects that it's running cooler, it will slow down its onboard fan.
  • Multi-chip cooling
    The HG10 A1 bracket combined with your Hydro Series cold plate provides excellent cooling for not only your GPU, but also your VRAM and VRMs.
  • Compatible with Reference Design AMD Radeon 290 and 290X GPUs
    The HG10 A1 fits GPUs based on the AMD Radeon 290 and 290X reference designs. Not sure if yours is compatible? Check the compatibility list on the tech specs page.
  • Works with all Hydro Series liquid CPU coolers
    The HG10 A1 works with the Hydro Series liquid CPU cooler you already have, and it's compatible with the entire Hydro Series line. Have you upgraded your original Hydro Series liquid CPU cooler, and have an older model lying around? This is the perfect application for it.
CORSAIR Hydro Series HG10 - video card liquid cooling system bracket
Video card liquid cooling system bracket
Video Card Compatibility
NVIDIA GeForce GTX 670, NVIDIA GeForce GTX 660Ti, NVIDIA GeForce GTX 760, NVIDIA GeForce GTX 970 series
27.2 cm x 11.3 cm x 6 cm
310 g
27.2 cm
11.3 cm
6 cm
310 g
Heatsink & Fan
Limited warranty: - 2 years
