Corsair HD120 RGB LED Static Pressure Fan with Controller
Quicklinx: CCLLWS00 Mfr#: CO-9050066-WW
Corsair Air Series LED high airflow PC case fans combine efficient, low-noise airflow with striking LED lighting. The custom-molded blades are designed for high-volume air delivery with less noise and turbulence than typical case fans. They're translucent, with a frosted texture, so the light from the four LEDs adds a dramatic effect.
Air Series AF fan models perform best in unrestricted spaces with at least 3 cm of clearance, and they're ideal for mounting at the rear or top of your PC case as exhaust fans for your PC's motherboard and CPU, graphics accelerators, and other components that fill the case with heat. They work equally well as unrestricted intake fans for areas like side panels or bottom intakes.
  • Quiet performance, vivid illumination
    The CORSAIR HD120 RGB LED PC case fans combine 12 independent frame mounted RGB LEDs and excellent air delivery, bringing a stunning element to your rig.
  • Control your look - and your cool
    Under control of an easy-access 3-button controller, set your fans to stun with fading, breathing, blinking and other LED modes. The HD120 RGB LED fans are tailor-made for those seeking to make their rigs outshine all others.
CORSAIR Air Series LED HD120 RGB High Performance - case fan
Case fan
Package Content
Mounting screws for case fans, 6-port RGB LED hub, fan RGB LED controller
White, blue, yellow, red, green, orange, violet
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Hydraulic bearing
Rotation Speed
800-1725 rpm
Air Flow
54.4 cfm
Noise Level
18 - 30 dBA
Power Connector
4-pin fan connector
Pulse-width modulation (PWM) support, RGB LED x12
Case fan
Package Content
Heatsink & Fan
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Hydraulic bearing
Rotation Speed
800-1725 rpm
Air Flow
54.4 cfm
Air Pressure
2.25 mm
Noise Level
18 - 30 dBA
Power Connector
4-pin fan connector
Operation Voltage
7 - 13.2 V
Mounting Kit
Included
Limited warranty: - 2 years
