Corsair Graphite 760T Windowed Full Tower Gaming Case Arctic White
Quicklinx: 98WNWS00 Mfr#: CC-9011045-WW
The Graphite Series 760T features an industry-first fully windowed side panel, but don't let its looks fool you - it's got tons of expansion room and cooling capabilities. With nine expansion slots, room for a 360mm radiator up top and a 280mm radiator in front, six tool-free, modular hard drive bays and four side-mounted SSD trays, you'll have a hard time filling it up with parts. And with dual front AF140L LED intake fans and a single AF140L rear exhaust, you'll have tons of airflow to keep everything nice and cool.
The 760T gives you a ton of flexibility to build the gaming rig you've always dreamt about. And the full side panel window gives you the freedom to show it off.
  • Gorgeous full panel window for maximum visibility of your internal components.
  • Hinged side panels with quick release latches for easy access.
  • Generous expansion room for building high-performance systems.
  • Tool-free SSD, Hard Drive, and Optical Drive installation.
  • Includes three AF140L fans, (front fans with LEDs) with room for up to seven fans. (NOTE: Black version has RED LED on front fans, Arctic White version has WHITE LED on front fans)
  • Fan speed toggle switch allows you to set your fans to "silent" or "performance" modes.
  • Modular drive cage system for highly customizable layouts.
  • Two modular drive cages house three 3.5" or 2.5" drives each.
  • Four tool-free dedicated SSD cages, sideways mounted.
  • Designed for fast and straightforward builds.
  • Radiator and fan compatibility: Top: 3 x 120mm or 2 x 140mm, Front: 2 x 140mm or 2 x 120mm (2 x 140mm LED included), Bottom: 1 x 120mm, Rear: 1 x 140mm or 120mm (140mm included)
  • Two USB 3.0 and two USB 2.0 front panel connectors, plus headphone and microphone.
  • Easily accessed dust filters.
  • Excellent cable routing with rubber grommets for clean builds.
  • Nine expansion slots for multiple PCI-E devices or large motherboards
  • Maximum CPU Cooler Height 170mm
  • Maximum GPU Length 450mm
  • Maximum PSU Length 230mm
  • Swing-out side panels
    The side panels are hinged, so opening your 760T is as simple as pulling the flush-mounted latch. They can also be removed entirely by simply lifting them off of the hinges.
  • Ample cooling potential
    Like all Corsair cases, the 760T is designed for high-performance system builds, and high-performance systems require sophisticated cooling. There are eight total fan mounts, with room for top, front, bottom and rear-mounted radiators.
  • A clever drive bay design that maximizes interior volume
    The four SSD bays are mounted laterally to make the most efficient use of the interior space. The combo 3.5"/2.5" drive bays employ a modular bay system, so you can remove the bays you don't need. The end result is an open interior optimized for extra-long GPUs and free airflow.
  • Front I/O panel with USB 3.0 and USB 2.0 connectors
    You can never have too many devices. The 760T front panel has two high-speed USB 3.0 connectors and two USB 2.0 connectors, plus headphone and microphone connectors for your headset.
  • Dual LED front intake fans with dual-speed control
    The fans are custom-engineered by Corsair to deliver high-volume airflow with less noise and turbulence. The extra-large diameter allows them to run at a lower RPM, and they're positioned to deliver cool air directly to your GPUs. A front panel switch allows you to toggle between silent and performance modes.
CORSAIR Graphite Series 760T - tower - XL-ATX
System cabinet
Tower
Windowed Side Panel
Arctic white
I/O Connectors
2 x USB 3.0 , 1 x headphones , 1 x microphone , 2 x USB 2.0
Supported Motherboards
ATX, microATX, Mini-ITX, Extended ATX, XL-ATX
System Cabinet Features
Screwless drive bays, fan speed controller, front dust filter, cable management holes, modular HDD brackets, supports 240 mm radiator in front panel, supports 240 mm radiator in top, supports 120 mm radiator in rear, screwless side panels, supports 280 mm radiator in top, supports 280 mm radiator in front panel, supports 360 mm radiator in top, supports 140 mm radiator in rear, supports 120 mm radiator in bottom
No power supply (ATX)
24.6 cm x 56.8 cm x 56.4 cm
11.2 kg
Tower
Windowed Side Panel
Max Mainboard Size
XL-ATX
Internal Bays Qty
10
Front Accessible Bays Qty
3
Product Material
Steel
Arctic white
Cooling System
Front: 140 mm fan x 2 / intake / white LED , Rear: 140 mm fan x 1 , Top: 120/140 mm fan mount x 3 , Bottom: 120 mm fan mount x 1
CPU Cooler Max Height
170 mm
Video Card Max Length
450 mm
Power Supply Max Length
240 mm
Expansion Bays
3 (total) / 3 (free) x front accessible - 5.25" , 6 (total) / 6 (free) x internal - 2.5" / 3.5" shared , 4 (total) / 4 (free) x internal - 2.5"
Expansion Slots
9
2 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack , 2 x USB 2.0
No power supply
Specification Compliance
ATX
24.6 cm
56.8 cm
56.4 cm
11.2 kg
