Strafe RGB MX Silent delivers ultra-quiet mechanical key switch performance and dynamic multicolor lighting control. It's up to 30% quieter than other mechanical gaming keyboards without sacrificing the speed, feel and responsiveness you need to win, and with virtually unlimited backlighting customization it looks as great as it plays.
Multi-color dynamic RGB backlighting
Brilliant RGB LED backlighting immerses you in the game with virtually unlimited adjustability. -
USB pass-through port
It's ready for your mouse, phone, or wireless headset adapter, and strategically positioned for uninterrupted game play by keeping the cable out of the line of fire. -
FPS and moba keycap sets
Personalize your Strafe RGB for your game of choice. The textured, contoured keycaps enable enhanced grip and feel. -
Detachable soft-touch wrist rest
It's textured to provide just the right amount of grip to keep your hands in place and provide long-lasting comfort. -
Gaming grade circuitry
100% anti-ghosting with 104 key rollover on USB ensures that every keypress registers, no matter how fast you play. -
Easy-access multimedia controls
Make on-the-fly audio adjustments without interrupting your game. And when you're not competing, they provide an easy way to play, pause, and skip audio tracks. -
CUE it up
CUE Link harnesses the power of CUE to connect your Corsair RGB keyboard, mouse, and headset to work in harmony for the ultimate lighting experience. -
Fully programmable
Reassign any key, or set up the most extreme macros for effortless gaming control.
- CORSAIR Gaming STRAFE RGB Mechanical - keyboard - UK Input Device
- Keyboard
- Backlit
- Interface
- USB
- Connectivity Technology
- Wired
- Localization and Layout
- UK
- Keys Qty
- 104
- Hot Keys Function
- Multimedia, programmable, Windows key lock
- Numeric Keypad
- Gaming
- Key Switch Type
- CHERRY MX Silent
- 44.8 cm x 17 cm x 4 cm
- 1.352 kg
- 2-year warranty
- Keyboard
- Backlit
- Interface
- USB
- Keys Qty
- 104
- Hot Keys Function
- UK
- Keyboard Technology
- Mechanical
- Key Switch Type
- CHERRY MX Silent
- Gaming
- Palm Rest
- Numeric keypad
- 44.8 cm
- 17 cm
- 4 cm
- 1.352 kg
- USB 2.0
- Included Accessories
- Keycap puller, FPS and MOBO keycap sets
- OS Required
- Microsoft Windows 7 / 8 / 10
- Limited warranty - 2 years
