After 20 years of pushing the limits of innovation, Corsair Gaming takes the power of Cherry MX German engineering one step further. With the simple goal of delivering pro-proven mechanical performance paired with outrageous customization options, Strafe will enable your skills to reach their full potential. Brilliant backlighting is enhanced with virtually unlimited dynamic lighting configurations - craft your own, or choose from six unique presets. And, gold contact Cherry MX mechanical keys deliver the ultimate competitive advantage. Rated for an industry-leading 100 million key presses, they guarantee a lifetime of consistent, comfortable response.
- Cherry MX Switches - Fast, precise, durable Cherry® MX
- Per Key Backlit - Backlighting for outrageous customization
- Fully Programmable - Reassign and create any key combo
- USB Port - Easily connect most devices via USB
- Comfort and Control - Textured and contoured keycaps
- Gaming Circuitry - 100% anti-ghosting for however fast you play
- Easy Access Media - Adjust your media volume on the fly
CHERRY MX RED KEY SWITCHES
Used by the pros and built in Germany. Cherry MX gaming keys feature the worlds leading mechanical key switch technology. Gold-Crosspoint contacts, Gold-plated contact closure, and pressure resistant metal alloy springs, give every gamer the competitive advantage.Delivering smooth, linear key responses with a wide actuation zone. They have the responsiveness you need for perfectly executing double and triple taps and there's no audible click or tactile "bump."
DYNAMIC BACKLIGHTING
Brilliant RED backlighting enhances the experience with virtually unlimited lighting adjustability. Choose from six unique presets or craft your own.
ENDLESS PROGRAMMABILITY
The Corsair Utility Engine (CUE) unlocks amazing keyboard programmability. Reassign any key or set up the most extreme macros for outrageous gaming control.
GET CONNECTED
Positioned for uninterrupted game play, the built in USB pass-through provides easy connection for your mouse, USB drive, or wireless headset adapter.
COMFORT AND CONTROL
Textured and contoured keycaps allow for maximum grip and enhanced feel. Personalize your experience by selecting between FPS and MOBA kits.
GAMING GRADE CIRCUITRY
100% anti-ghosting with 104 key rollover on USB ensure no matter how fast your play, all your keys register.
AUDIO ON THE FLY
Enhanced easy-access multimedia keys efficiently allow for on the fly audio changes while gaming. And when you're not gaming, you can effortlessly play, pause, and skip audio tracks.
Cherry MX key switches
Used by the pros and built in Germany, Cherry MX gaming key switches feature the amazing mechanical key switch technology. Gold-crosspoint contacts, gold-plated contact closures, and pressure-resistant metal alloy springs give every gamer a competitive advantage. -
Dynamic backlighting
Brilliant RED backlighting enhances the experience with virtually unlimited lighting adjustability. Choose from six unique presets or craft your own. -
Endless programmability
The Corsair Utility Engine (CUE) unlocks amazing keyboard programmability. Reassign any key or set up the most extreme macros for outrageous gaming control. -
Get connected
Positioned for uninterrupted game play, the built in USB pass-through provides easy connection for your mouse, USB drive, or wireless headset adapter. -
Comfort and control
Textured and contoured keycaps allow for maximum grip and enhanced feel. Personalize your experience by selecting between FPS and MOBA kits. -
Gaming grade circuitry
- CORSAIR Gaming STRAFE Mechanical - keyboard - UK
- Keyboard
- Backlit
- Interface
- USB
- Connectivity Technology
- Wired
- Localization and Layout
- UK
- Keys Qty
- 104
- Hot Keys Function
- Multimedia, programmable, Windows key lock
- CHERRY MX Red technology
- Gaming
- Key Switch Type
- CHERRY MX Red
- 44.8 cm x 17 cm x 4 cm
- 1.352 kg
- 2-year warranty
- Keyboard
- Backlit
- Interface
- USB
Input Device
- Keys Qty
- 104
- Hot Keys Function
- UK
- Keyboard Technology
- Mechanical
- Key Switch Type
- CHERRY MX Red
- Gaming
- 44.8 cm
- 17 cm
- 4 cm
- 1.352 kg
- USB
- Included Accessories
- Keycap puller, FPS and MOBO keycap sets
- OS Required
- Microsoft Windows 7, Windows 8, Windows 10
- Limited warranty - 2 years
