Corsair Gaming MM400 High Speed Gaming Mouse Pad
Quicklinx: BP0MWS00 Mfr#: CH-9000103-WW
The surface of the MM400 is made of a high-quality, long-lifespan polymer. It's tuned to deliver outstanding glide characteristics without sacrificing control, allowing for both consistent snap targeting and pixel-precise shots. The tuned micro-texture surface is optimized for gaming sensors, so you get a better glide feel without sacrificing control or accuracy.
The CGMM400 is stable and secure. You can't afford to have your mouse surface move in the middle of a firefight, so Corsair added a non-slip base that provides cushion with just the right amount of give. And it's made of natural rubber, so it doesn't have a harsh chemical odor.
CORSAIR Gaming MM400 Standard Edition - mouse pad
Mouse pad
Product Material
Plastic, rubber
35.2 cm x 27.2 cm
1-year warranty
Mouse pad
Product Material
Plastic, rubber
35.2 cm
27.2 cm
Thickness
0.2 cm
Non-slip
Limited warranty - 1 year
